1 gen back up light bulb upgrade/other options?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cali. Camper, Oct 7, 2019.
  1. Oct 7, 2019 at 10:44 PM
    Cali. Camper
    Cali. Camper [OP] Deserted Desert Guy
    Eric
    Arizona
    ‘00 Tacoma TRD Extra Cab
    Super charger, i8000e Warn wench, BFG km3 33”x10.50, leer shell with defender rack. 5100 Bilsteins.
    What options do I have for back up lights, or installing flush mount rigid light, ect.
  2. Oct 8, 2019 at 12:45 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Pretty much whatever you want .
    Since my mornings always start in the dark I use additional reverse lights to see.
    Over the years I have mounted them in several different ways .
    It comes down to your driving use I have torn a few off over the years
    I was toying with the idea of a LED light bar mounted on my rear window protection rack just never installed anything.
  3. Oct 8, 2019 at 5:42 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
  4. Oct 8, 2019 at 6:01 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    I put some led pods under my rear bumper and wired them in line with the reverse bulbs. They worked fine till I ripped them off while wheeling :burp:
    I put some auxbeam led reverse bulbs in and they don't do much for me
    Bivouac and cruiserguy like this.
  5. Oct 8, 2019 at 7:07 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  6. Oct 8, 2019 at 7:43 AM
    MamaTried81
    MamaTried81 Well-Known Member
    Oakland, CA
    '02 TRD Tacoma 4x4 V6 XtraCab SR5
    Cali. Camper[OP] likes this.
  7. Oct 8, 2019 at 8:53 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
  8. Oct 8, 2019 at 10:44 AM
    Nate0303
    Nate0303 Well-Known Member
    Nathan
    03 Tacoma TRD
    3in lift on 285/75r16 toyo MTS, cbi Moab front bumper, headache rack, nfab Nerf bars, LED lights, double din head unit, kicker hideaway dub
    I'd recommend starting out by replacing your reverse lights with some LEDs. I did this a few years ago and it made a world of difference. Got them from superbrightleds for pretty cheap. Snapchat-325444902.jpg
    frizzman likes this.
  9. Oct 8, 2019 at 12:30 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    And you really believe what Amazon description says :rofl:. 1000 lumens in my fat a$$. I have them, they are 350lm max. Same with the other Amazon bulb from post #6: "Lumen: 1000LM/bulb; Wide Operating Voltage: 12V-24V DC; Current: 310MA; Wattage: 3.7W/Bulb; Length: 1.63", Diameter: 0.83"." - they are close to 350 lm too.
    But, the truth is this is the best you can get from bulb that size. 350lm is close to what stock output is (actually incandescent P21W made by Osram is better with 420lm), it just the color makes it look "brighter". The only benefit of using LED replacement in stock socket is reducing the current running through wires - for 20 years old truck is it good thing.
    By the way I have tested a bulb that size advertised as 2000 lm but the design was a bit different - it does have heat sink to keep LED chips in operating condition and mounts "through hole" (exposing heat sing on the back side of reflector).
    It started at quite promising at 1.2A (over 1200 lm) but within two minutes the bulb get to hot and the internal circuit limited the current o 0.5A - that is 6W (about 600 lm). Still better than 350lm but that design will not fit into our reverse lamp housing anyway.
  10. Oct 8, 2019 at 12:58 PM
    jbrandt
    Justin
    First, that 1000 lumens is likely for the pair, so 500 each is much closer to your 350 "max".
    Second, I couldn't care less what the actual lumen output is, what it is rated at, or what the seller claims it to be. 4, or elevendy billion lumens.
    What matters is that these things light up my neighbor's house when I back out. Stock lights I could barely see my own fence.
    The seller could claim they are powered by unicorn farts for all I care.
  11. Oct 8, 2019 at 1:48 PM
    RysiuM
    Rysiu
    From that Amazon link:
    I'm just pointing out that most of e-bay and Amazon "description" is not even close to the truth. It is simple bullshit and should not be repeated on such nobble place like TW :).
    By the way do not trust pictures either - high K light looks brighter through camera chip than it is. This is why all pictures with 6K bulbs look "Oh my God, they are so bright" :rofl:
    By the way, I have exactly the same Amazon bulbs for reverse in my 4Runner. Yes, they are frigen bright and I light the whole neighborhood when I'm backing up, at least this is my perception :thumbsup:. But the truth is they are the same as my old bulb I replaced them with. Just the color is "cool". And what is the most important for me (new car or old) they take less power, less current is running through all contacts and switches, less chance of heat damage. And the same goes for my Tacoma bulbs (Yes, I have LED everywhere there except headlights)
  12. Oct 8, 2019 at 2:23 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I did the same, bought some 921s from SBL and they work great.
  13. Oct 8, 2019 at 10:49 PM
    Cali. Camper
    Eric
    Arizona
    Thanks for all the intel folks! Im going with the jdm astar 1200, I read all your posts, like the quick fix!
  14. Oct 10, 2019 at 7:49 AM
    TacoTaco02
    TacoTaco02 Well-Known Member
    Illinois
    02 Ext Cab SR5 TRD 4x4 V6
    I've been happy with my Sylvania Zevos reverse light led's though its in my daily driver car. Expensive, but worth it and isn't like the other cheap junky led's that put the diodes all over the place using junky components.
    If sellers only show pictures at night it is for a reason. The biggest struggle of led's are to match the light output and clarity as incandescents during the day. Night time is easy and cameras exaggerate the light.
  15. Oct 15, 2019 at 10:42 AM
    Cali. Camper
    Eric
    Arizona
    These bulbs listed below do not fit 2000 tacoma
  16. Oct 6, 2022 at 9:58 PM
    YodaLovesTacos4x2
    YodaLovesTacos4x2 Active Member
    Lou Sassle
    East Fishkill, NY
    98' 5 lug RegCab DLX
    Camper bed cap, led fog lights, LED/HID upgrade kits for highs & lows, custom paint job, +/- 4" lift (more like 3" on the driver's side and 5" on passenger side...gotta love the taco lean), big 5 wire upgrade, custom painted interior, satin black paint job that looks like shit because it was my first time painting a vehicle, custom audio system and a big booty butt load of random off road and work lights. That being said it is a DLX and I really didn't need to do any mods because obviously it's the DELUXE edition
    Just for clarification to anybody who is reading this thread and is confused like I was: as far as first gens go 1998 to 2000 uses 1156 and 1157 (dual filament) bulbs for all three tail light applications (1157-brake/ running lights, 1156-directional, and 1156-reverse) whereas in 2001 it appears they switched to a t-15/921 style bulb...at least for the reverse light as far as I can tell I'm not sure about the directional and brake lights but I would assume that those would also have undergone the switch. Maybe someone with a 2001-on could confirm this.
    Also not sure what style bulb was used in the 95-97 models but I assume it's the same style as the 98-00 models.
    andywear likes this.
  17. Oct 7, 2022 at 5:15 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    still 1156 (turn) and 1157 (run/brake)
  18. Oct 7, 2022 at 8:25 AM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
  19. Oct 7, 2022 at 9:28 AM
    YodaLovesTacos4x2
    Lou Sassle
    East Fishkill, NY
    So they just changed the reverse light then. I stand corrected. I guess that makes sense to switch to a bulb that's capable of higher light output for reversing only this way you're not blinding the driver behind you everytime you come to a stop or make a turn.
    Anyways I use the 1156/1141/7506 bulbs that some AutoZones sell.... Sylvania zevo I believe.. they're decent definitely brighter than the stock bulbs but I also have quite a few options for lighting up the road behind me if: it's super dark and the sylvania's aren't cutting it, when I'm using the reverse camera, Or if someone behind me is blasting me with their brights
    Those work lights on top of the cap put out some lumens too. 20221007_121642.jpg
  20. Oct 8, 2022 at 4:08 PM
    leid
    Brandon, MS
    I have these bulbs coming now and will post feedback once installed.
