1.75" Bilstein and Cooper Discoverer AT3 LT275/70R17 (Load C)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lola, Mar 23, 2016.
  1. Mar 23, 2016 at 9:01 PM
    Lola
    Lola [OP] Member
    British Columbia
    2012 TRD DC LB
    Bilstein 5100s set at 1.75" and rear 5100s with Firestone Ride Rite air bags, BFG All Terrains 265 70/17, Devil Horns, Nfab light bar, Baja Designs Squadron Pros, led bed lighting, trailer harness relocation bracket, Arrow topper, custom ski rack
    Anyone running Cooper Discoverer AT3 LT275/70R17 (Load C) with 5100 Bilsteins set at 1.75" on stock OEM coils? I will probably go with a 265/70/17 due to weight and fit, but I am curious...
    The Cooper AT3 275/70R17 Load C weigh in at 53 lbs compared to BFG All Terrain 275/70R17 Load E at 55.4 lbs.
    Thanks.
  2. Mar 24, 2016 at 9:56 AM
    ZRXDean
    ZRXDean Well-Known Member
    Langhorne PA
    DCLB - Pabst Metallic
    OME 885, Billstein 5100, Deaver 2" AAL, ARE CX Cap, Go Rhino Dominator steps
    I'm running the Cooper AT/3 265/70/17 but with 885x and Billys at 0. Only have a couple hundred on them but happy so far.
    Look at price and weight when considering the 275 - that was deal-breaker for me........
  3. Mar 24, 2016 at 9:59 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    eff that weight!!! Hankook Dynapro ATM RF10's P265/75R16's are 39lbs per tire!
  4. Mar 24, 2016 at 10:07 AM
    ZRXDean
    Langhorne PA
    The 265 cooper is 41.
  5. Mar 24, 2016 at 10:20 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Almost................Do have 5100s set @ 1.75 on stock coils. AT3's, NTG's & one other were on my short list for new tires recently. Punked out and went with NTGs again because of the known factor of price, how they look on the truck, how they act & how they last. Sorry, no help.
  6. Mar 24, 2016 at 10:27 AM
    iitywygms
    iitywygms Well-Known Member
    Norcal
    4x4
    I have that setup except I am at .85 in front.
    Tires wear good, handling is okay. Cant really compare to anything else as they are all I have run since getting my truck.
    I have a occasional vibration up front sometimes at highway speed. Balanced the tires several times but still shake. Last few weeks I found my front driver side axle is loose because the needle bearing is shot. Once I fix that I will no better if the vibe is from the tires or the axle.
  7. Mar 24, 2016 at 9:45 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    I'm interested in the same setup. Question is how the AT3's perform off-road.
    oh second point, I hear Load C just rides nicer than Load E
  8. Mar 24, 2016 at 11:40 PM
    GeoBruin
    GeoBruin Well-Known Member
    BJ
    Los Angeles
    White 2014 Double Cab TRD Off Road
    OP, you got your weights mixed up. The Cooper Discoverer AT/3 is 53 lbs in the E load. C load is 47 lbs.
    I did some rough calcs (okay actually not so rough) and I figured out that the mass moment of inertia of a 275/70r17 AT/3 is actually less than that of a 265/75 r16 BFG ko2 in the 10 ply (load E) let alone the 275 BFG.
    In fact, the AT/3 comes in a 285/70r17 that is a 4 ply (B Load) that weighs about the same as the 275/70r17 Load C and has very similar inertial specs.
    In short, fear not! Go big!
  9. Mar 24, 2016 at 11:58 PM
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    Are you going to run aftermarket wheels? If not I would not stress the weight in the least. Also I'm set at 1.75 up front however running toytecs adustable Bilstein on 265/70/17 duratracs and if you aren't running the right psi everything will run hard and rattle the crap out of your insides. Go 265 gy duras no trimming and will give you a meatier look, hum, and good all around drivability
  10. Mar 26, 2016 at 8:22 PM
    Lola
    Lola [OP] Member
    British Columbia
    2012 TRD DC LB
    Update on my findings...
    I've been checking around with local tire shops and they are all pushing the BFGs KO2s in 265/70/17 load C. I have been told the Cooper AT3 275/70/17 load C are too tight and require minor inner fender trimming, removal of front mud flaps and tire runs very close to the UCAs. I want to keep my flaps.
    I see a lot of Tacos running 265/70/17s with either spacers or Bilsteins and they look too small.
    Anybody else out there running the 275/70/17 setup with stock aluminium wheels, 1.75" setting on Billys with OEM coils?
    Thanks!
  11. Mar 26, 2016 at 9:30 PM
    Powersrp
    Powersrp Well-Known Member
    Army E-7
    mackinaw city. mi
    2012 tacoma 4x4 trd sport, V6 auto
    running 265 70 18's at3, excellent tire, yes, some front end shake that wouldnt balance out, and they will float when hitting standing water. run mine at 30 psi
  12. Mar 27, 2016 at 5:31 AM
    bski22
    Rob
    Toyota
    @Lola hey man here are some images of my truck pre front bumper install and the day of. Either way it's a good way to see 265/70/17 duratracs on 17x8.5 wheels. There is no way if you go up 1.75 up front that you should need to trim a thing. That's assuming you are going aftermarket wheels. Hope the images give you an idea of what you're trying to gain about sizing and looks. I can tell you first hand that there is very little diffence from 265 through 285 and as long as you can have a good shop do your alignment you're going to be in great shape. Also remove the flaps those things rub the ground just going over large speed bumps.
    freedomriding likes this.
  13. Mar 27, 2016 at 6:37 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I currently have the AT3 - 285/70r17
    B-4 ply on Billies with the Eibach 521600 springs. Good tire - not too heavy.
    GeoBruin likes this.
  14. Mar 27, 2016 at 1:20 PM
    GeoBruin
    BJ
    Los Angeles
    Nice! Been hoping to see someone on here running the 4 ply. What's the gas mileage like? Also, which wheels are you running? I like the stance on your truck. Tires aren't sticking out 2 inches past the fenders. Awesome!
  15. Mar 27, 2016 at 5:32 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Aired up to 38 psi - on the interstate I'll get around 19 average - running 70-75mph. In town I run them at 33 psi.
    Wheels are 4Runner Trail 4th generation.
  16. Mar 27, 2016 at 8:25 PM
    GeoBruin
    BJ
    Los Angeles
    Did you have to use spacers or do any heavy duty trimming to clear the 285s?
  17. Mar 27, 2016 at 9:23 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    No trimming needed. But it's helpful to have adjustable upper control arms so you can center the lower arm in the wheel well then adjust your alignment via the top. That way there's no rubbing or cutting needed.
    My Bilsteins are at the lowest clip setting and the 521600 spring gives about 2" of lift. I do have a 1/4" lean top plate spacer on the drivers side.
  18. Mar 27, 2016 at 10:12 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    2" lift, stock wheels, 275 70 17s. No major rubbing issues.
