1.75" (1-3/4") LSPV (load sensing proportioning valve) Bracket Discounted (new)
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Beefed Taco, Dec 15, 2011.
  1. Dec 15, 2011 at 12:22 PM
    Beefed Taco
    Beefed Taco [OP] Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    I have a 1.75" bracket for trucks lifted 1.50" - 2" in back. This will restore the braking that was lost by using a mild rear lift and not raising the bracket on the axle up. Especially important for trucks that tow or have oversize tires. I made it for a guy that was going to do local p/u and never showed.
    Taken from my website
    LSPV Bracket (load sensing proportioning valve) $16.01
    Shipping $7.00
    Total $23.01
    Discounted Price with shipping included
    $15 (savings of $8.01)
    If interested, my PayPal info is my email address and can be found on the "Contact Us" page on my website by clicking my sig below.
  2. Feb 8, 2012 at 10:57 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
  3. Feb 10, 2012 at 7:51 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Maybe a dumb question but if the front is lifted too, so truck sits level doesn't that even out lifting the rear? Or does it not work like that???
  4. Feb 14, 2012 at 1:32 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    There is a valve located on the left side of the frame on 1st gens that has a rod that goes down to a bracket on the axle, and when you load weight into the bed, the rear lowers down, which moves the rod, which in turn makes the valve push more fluid pressure to the brakes, and makes them clamp tighter and quicker to compensate for the extra weight.
    When you lift the rear, the opposite happens, you lose brake prsssure and your rear brakes don't work as well as they should. Add larger tires and a trailer and your front brakes are doing 90% of the work. Not good.
    So it's a matter of the frame where the valve is, going closer or further away from where the lower end of the rod attaches at the axle, nothing to do with the truck sitting higher or lower in the front compared to the rear.
  5. Feb 14, 2012 at 2:04 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Thanks for that good explanation! Hmmmm......
  6. Feb 14, 2012 at 2:11 PM
    Ohbrian
    Ohbrian Taco Roja
    Brian
    Fremont, CA
    04 PreRunner
    Eclipse head unit,scratched paint,ripped seat, black chaos 6 rims, Bilstein 5100's, top plate spacers, AAL, Midget antenna, Bakflip G2 cover, 14" Magnaflow, 400W inverter, LR UCA's
    You still have any for a 3" lift?
  7. Feb 16, 2012 at 10:55 AM
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
  8. Feb 16, 2012 at 11:03 AM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    Bump beefed makes great stuff. I have his 3" bracket.
  9. Feb 22, 2012 at 1:04 PM
    cltypes32
    cltypes32 Well-Known Member
    PNW
    02 SR5 TRD 4x4
    ARE, DR C/O, Icon Resi, OME Dakars, ARB bumper, KR Fab Sliders
    I'll take it if you still have it?
  10. Feb 25, 2012 at 2:00 AM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    It's boxed and ready to go. Shoot me a PM with your info and I'll get it on the USPS truck tomorrow, priority mail, you'll have it Monday. I'll PM you my PayPal info right now.
  11. Feb 25, 2012 at 9:46 AM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    if he flakes, ill take it
  12. Feb 25, 2012 at 5:21 PM
    cltypes32
    PNW
    02 SR5 TRD 4x4
    Payment sent. Thanks!!
  13. Feb 26, 2012 at 2:32 PM
    biggecko
    biggecko Well-Known Member
    Tarek
    Apex,nc
    2000 TRD SR5 pre-runner v6 3.4
    nerf bars, deckplate mod, billys 5100 all the way round with an aal in back
    I know you prob already sold it but I have a question, I did the volatile 5100 lift with 2" aal from toytec in back and when I brake my rear tires never lock up even after my front ones have even off road, would this fix that?
  14. Feb 28, 2012 at 1:31 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    My guess is it probably will. In the past I've received feedback regarding the difference in braking feel. I though it was great that this simple item actually made a difference you can actually feel. I have these on my website if you click my signature below you'll be taken to it. On the home page click Products and then find & click Categories and lspv (or BPV) and you'll be taken to them.
