1.5 to 2 inch lift kit for 2013 Taco Please!!
Discussion in 'Suspension' started by atm0016, Jun 13, 2013.
  1. Jun 13, 2013 at 8:14 AM
    atm0016
    atm0016 [OP] Member
    Aaron
    Columbia MO
    2013 Double cab 4x4
    Hello fellow Taco owners,
    This is my first post. I'm looking for a 1.5 to 2 inch lift to allow for slightly larger tires(265/70 R17). I'm going to get flack for admitting this, but I ordered a Ready lift (2.75-3 inch spacers for front and 2 inch block for rear)for my new 2013 Taco and was unable to install it due to the front coils rubbing the UCA's. So I guess I need new coil overs, but I don't want to limit travel. What would be my best setup? Any help is appreciated.
  2. Jun 13, 2013 at 8:17 AM
    Large
    Large Red
    Coils shouldn't rub the UCAs with a spacer lift unless it was designed for another vehicle, if you want a good front lift that's about 1.5" go with eibach coils and 5100s. If money isn't an issue get some king extended travels (you need new ucas for them).
  3. Jun 13, 2013 at 8:25 AM
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
    I'm running readylift spacer. Don't know how much you paid for it but I do know readylift ain't as cheap as other spacers of eBay. I personally would go with 5100's. Do it right the first time. Your gonna hate that 2 inch block in the rear as well.
  4. Jun 13, 2013 at 8:39 AM
    atm0016
    atm0016 [OP] Member
    Aaron
    Columbia MO
    2013 Double cab 4x4
    I thought that too, but when I called ReadyLift, they told me about 1 out of every 8 TRD trucks have this problem. Not sure why or how. Do you have any recommendations on a website to purchase eibach coils from?
  5. Jun 13, 2013 at 8:44 AM
    TACO FOR LIFE
    TACO FOR LIFE Well-Known Member
    Seth
    texas
    07 PreRunner
    I just got my ready lift off ebay for my 2007 still havn't done install yet but hopefully i wont have the same problem
  6. Jun 13, 2013 at 8:46 AM
    Large
    Large Red
    toytec .. go to their vendor section and they have a coupon code you can use when you checkout, it's basically free shipping.
  7. Jun 13, 2013 at 8:53 AM
    atm0016
    atm0016 [OP] Member
    Aaron
    Columbia MO
    2013 Double cab 4x4
    Thanks Large!!! Would you recommend the differential drop kit for a 1.5" to 2" lift? Some posts recommend it if you are over a 2" lift.
  8. Jun 13, 2013 at 10:21 AM
    monstertaco12
    monstertaco12 Quack Addict
    Louisiana
    2012 Taco TRD Off Road
    Go to toytech and get either the 5100s with eibachs, the toytech ultimate lift kit or in my opinion the OME setup is the best bang for your buck. Right around $1000 with free shipping if you order the OME setup from trdparts4u.com and use the coupon code ome10 for 10% off...
  9. Jun 13, 2013 at 10:23 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
  10. Jun 13, 2013 at 11:26 AM
    atm0016
    atm0016 [OP] Member
    Aaron
    Columbia MO
    2013 Double cab 4x4
    Are you talking about the TACOMA OME NitroCharger Sport Suspension Kit (OME-TACO-0513B)
  11. Jun 13, 2013 at 11:49 AM
    bzzr2
    bzzr2 Well-Known Member
    i suggest the ome struts, ome 884 coils and an add-a-leaf along with some new longer than stock rear shocks, there are several out there, personally i run sky jacker rear shocks that are about an inch longer than the ome rears, which are only 1 inch longer than stock rears.. alternatively some ppl run the ome dakar rears with a leaf removed, this will be better than the add-a-leaf option in the long run. you will not need a diff drop or new control arms.
  12. Jun 13, 2013 at 12:05 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    OME-TACO-0513B- Full OME setup. 885s in the front. Get rid of your sway bar, you won't need it. Dakars out back, pull a leaf so you don't have a ton of rake. It's going to be a little over 2" of lift, but you'll enjoy the ride and the peace of mind having done it right.
    Slap all that new sweetness onto your truck and have a nice day.
  13. Jun 13, 2013 at 1:57 PM
    atm0016
    atm0016 [OP] Member
    Aaron
    Columbia MO
    2013 Double cab 4x4
    Would you recommend a differential drop kit in for only 2 inches of lift?
    Ryans4×4 likes this.
  14. Jun 13, 2013 at 1:59 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
  15. Jun 14, 2013 at 3:38 AM
    monstertaco12
    Louisiana
    I couldnt find it but there is a thread on here explaining why diff drops on 2nd gens are pointless. Especially with only 2" of lift. Some people run them fine but ive seen some people cause more damage than good when wheeling so save the cash on that and go with the OME kit!
  16. Jun 14, 2013 at 3:43 AM
    BostonBilly
    Easton
    No you dont need a DD or a sway bar relocate with the 2" lift at least I dont need the swaybar relocate with the IronMan lift.
  17. Jun 14, 2013 at 9:31 AM
    blazer190
    blazer190 Active Member
    Walker Louisiana
    TRD offroad 4X4
    I have a 2011 double cab trd off road 4x4 with a 3" front and 1" rear ready lift with no issues what so ever. Is it only rubbing the coils when jacked up?
    What did it do when you put the tires on it and put weight on the front end
  18. Jun 15, 2013 at 9:23 AM
    atm0016
    atm0016 [OP] Member
    Aaron
    Columbia MO
    2013 Double cab 4x4
    It didn't get that far. My dealership stopped the install because the sway bar was rubbing the coils. ReadyLift told them to space the sway bar with washers, but the dealership didn't want to rig it. I don't blame them. Adding washers would space it, but the gromet would have been loose.
  19. Jan 4, 2015 at 8:33 PM
    Dsb05016
    Dsb05016 Well-Known Member
    Dillon
    US
    Silver 06 Tacoma dcsb trd offroad 4x4
    Powder coated Trd offroads, upgraded tires(265/75r16), kool vue cold air intake, Billy's 1.75 front, rear Billy's and wheelers 1.5 hd aal (not installed), more to come
    You only need a dd if your drunk
