1/4" Spacers without new bolts, is this enough thread??
Discussion in 'Suspension' started by Bannerman, May 29, 2019.
  1. May 29, 2019 at 6:04 AM
    Bannerman
    Bannerman [OP] Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    I put my new JBA UCAs in last night and went ahead and put in some 1/4" spacers too just get a bit more lift. Everything I read said I shouldnt need new bolts/studs as long as I kept to a 1/4" but I'm a little uncomfortable with how little threads the nuts have on them, they are not threaded all the way down the "flange" at the bottom, just the nut part on top. Nuts snugged up fine but what do you guys think, maybe need to swap them out for new nuts? I guess there is no real load on on these bolts, just keep the shock seated when fully extended?
  2. May 29, 2019 at 6:29 AM
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    16 Super White TRD-OR DCSB
    ARB Locked, Nitro 5.29's, Cooper 315's, 16x8 Methods, Cab mount hacked, Firewall Hammered, OME Suspension, Camburg UCA's, ARB OBA, RCI skids and sliders, WarFab Front Bumper, Home Brew Rear Bumper, Orange Virus Tuned, Dobinson Snorkel, Cobra Comms...
    I would buy longer bolts, but new nuts would probably be fine. I wouldn't leave it the way it is.
    Bannerman[OP] likes this.
  3. May 29, 2019 at 6:35 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    That's fine. If you had 1/2" spacers, then you'd need new studs
  4. May 29, 2019 at 6:41 AM
    Bannerman
    Johnson
    Charlotte, NC
    I think it prob is fine, but for $2 I can prob get some new SS nuts, think it's worth the piece of mind. Thanks Gents. :hattip:
    TomTwo and TS7xTaco[QUOTED] like this.
  5. May 29, 2019 at 6:43 AM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Rule of thumb for thread protrusion is 1 1/2-2 threads.
    TomTwo likes this.
  6. May 29, 2019 at 6:43 AM
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    When I did a 1/4 spacer, I also replaced the studs and nuts and haven't had any issues fwiw...
  7. May 29, 2019 at 6:44 AM
    Bannerman
    Johnson
    Charlotte, NC
    The issue really is the nuts not being fully threaded. There is plenty of stud sticking up, but the lower part of the nut has no threads.
  8. May 29, 2019 at 6:46 AM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    I have had this exact setup for 3 years and no issue. I marked the nuts just to be sure. No worries.
  9. May 29, 2019 at 6:57 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    When I put the TRD Pro Suspension on I got new Nylock nuts from Wheelers
    Even with 1/4 in spacer added I have lots of threads remaining.
  10. May 29, 2019 at 6:58 AM
    Bannerman
    Johnson
    Charlotte, NC
    I'm going to pull one off and see if I can get a set of nylock nuts from Lowes. Are those stainless?
    Edit: Nevermind, found them.
