1/4 inch spacers
Discussion in 'Wheels & Tires' started by cwadej, Jul 19, 2020.
  1. Jul 19, 2020 at 12:16 PM
    cwadej
    cwadej [OP] Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    Tell me why these are a bad idea. [​IMG]
  2. Jul 19, 2020 at 3:58 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Yell us why you think they're a good idea.
  3. Jul 19, 2020 at 4:04 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    You could have just said you dont have a reason.
    MGMStudioTaco and 09 Redneck like this.
  4. Jul 19, 2020 at 4:10 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If you have factory wheels, they are hub centric and if you aftermarket wheels which should also be hub centric. The spacer will inhibit the wheel from sitting on the hub correctly and could cause wheel vibrations.
  5. Jul 19, 2020 at 4:11 PM
    Silverlogic
    Tyler
    I can think of many reasons why they're a bad idea, I'm struggling to think of a single reason they're a good idea.
    It's easier if we debunk why you think they're good rather than write you a 10 page engineering whitepaper on why they're retarded.
  6. Jul 19, 2020 at 4:13 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    :rofl::rofl::rofl:
    Silverlogic[QUOTED] and tcjacado like this.
  7. Jul 19, 2020 at 4:31 PM
    TexasED04
    TexasED04 Well-Known Member
    Brandon
    Houston, Tx
    04 Texas Edition PreRunner
    Well said :thumbsup:
    Gunshot-6A likes this.
  8. Jul 19, 2020 at 4:36 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    they are not OEM. I bought the truck with them on it. Only thing even hinting to brand is "prime-ks" in the casting on back side.
    I'm wanting to add spindle gussets, but dont want to use 1 inch + spacers, as I like the look I have.
  9. Jul 19, 2020 at 4:42 PM
    tcjacado
    tcjacado Well-Known Member
  10. Jul 19, 2020 at 4:50 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    I checked there a few months ago. Not on their website.
    tcjacado likes this.
  11. Jul 20, 2020 at 11:19 AM
    zw470
    zw470 Well-Known Member
    Marty
    I tried a set like that on my Wrangler many years ago. They were so badly machined you could actually see the tire wobble as you drove.
  12. Jul 20, 2020 at 11:21 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    why do you need a 1/4 inch spacer. Are you rubbing somewhere?
  13. Jul 20, 2020 at 11:25 AM
    MGMStudioTaco
    MGMStudioTaco Member
    Trey
    Charlotte, NC
    2018 MGM Tacoma Limited 4x4
    Grande Tires W/Kings
    it will give you less thread engagement which is the real downside and why I would never use them. If you want spacers get some that are hub centric and bolt on like spidertrax or Bora if I spelled those right. I have spidertrax and have had no issues. Just install them correctly.
  14. Jul 20, 2020 at 1:31 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    I do, lower LCA in the back, small spot when at full lock, but I'm wanting to add spindle gussets, but dont want to use 1 inch + spacers, as I like the look I have.
  15. Jul 20, 2020 at 1:32 PM
    cwadej
    Right Here
    2011 Access Cab 4x4
    or longer studs or extended nuts. I will not have anything over 1/4", period.
