06 short pin fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by booneboy, Jan 11, 2018.
  1. Jan 11, 2018 at 12:12 PM
    booneboy
    booneboy [OP] New Member
    I am seeking help regarding the white fuse located in the engine compartment fuse box on a 06 Tacoma. As you stand outside the car on the drivers side facing the passenger side, the fuse is located in the left row and is the 4th fuse running from the drivers side towards the passenger side. It is bright white in color. I was towing a snowmobile trailer that was just rewired and for trailer lights stopped working as did the heat in the cab. I tried to look figure out if a fuse was blown-it was dark and cold and I ended up pulling out the above described white fuse and dropped it into the engine compartment-never to be seen again.
    Since then I have made 4 trips to 2 dealers and made 2 calls to Toyota USA in an effort to get a new fuse. I have been told that this fuse is called a "short pin" and the part number is 82824-20140. That fuse does not fit. The dealer could not make it fit. It does not even look like the one I lost. It is crazy-they are unable to find the fuse. I spent hours trying to source this fuse and and getting very frustrated.
    In the event I can ever get past this fuse issue I then need to figure out what happened to the heat. Thanks if you can help.
  2. Jan 11, 2018 at 1:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The Short Pin is NOT a fuse. It is exactly what it is called a Short Pin in that when removed from the Tacoma it disconnects part of the electrical circuits that could drain the battery during storage and shipment as per the prints for the 2005 these circuits are: ECU-B, Dome Light and Radio NO.1.
    It is basically a jumper connection that ties those circuits into the electrical system.
    davidstacoma likes this.
  3. Jan 11, 2018 at 2:02 PM
    booneboy
    Call it what you will, I need to stick that thing in the fuse box and Toyota has no idea what it is so I do not have dome lights or radio until I can buy that thing that you stick in the fuse box.
  4. Jan 11, 2018 at 9:25 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Your dealer may be playing stupid, but they do know what it is as EVERY New vehicle that comes in they have to install that short pin into the proper location in order for it to work. This is done during the pre-delivery phase when the vehicles are being prepared for sale.
    IAW my information the part number that they gave you is correct and should work.
  5. Jan 11, 2018 at 9:59 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If all else fails and you cannot locate the short pin link. You can make a jumper using two properly sized male spade connectors and a short piece of 12 gauge wire and just jump across the connectors.
  6. Jan 12, 2018 at 5:07 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Isn’t there a diagram on the underside of the box lid? Might have some info there...
    You might want to post a pic so there’s no question about what fuse you mean. Are you sure you’re looking for the short pin? Good Luck OP.
  7. Jan 12, 2018 at 7:56 AM
    nasaengr
    nasaengr Well-Known Member
    Red15 DC OR
    If you can't find the right part you could just put a regular mini fuse in it's place. I think the largest mini they make is 40A. Here is my short pin next to a 20A fuse.
    Jimmyh likes this.
  8. Jan 12, 2018 at 8:14 AM
    tiredmechanic
    tiredmechanic Active Member
    Doug
    Swords Creek VA
    2006 White TRD
    Any salvage yards near you that it could be sourced from?
  9. Jan 12, 2018 at 3:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Better idea than my jumper idea.
  10. Jan 15, 2018 at 11:27 AM
    DaManIam
    DaManIam New Member
    Per Toyota Technical Support, you must order the fuse block in order to get this part. Foolish in my opinion, but it's their answer to the ST fuse debacle.
    "llPROTECTED 関係者外秘
    Hi DaMan,
    The short pin you are seeking is not available separately. It is included with PNC 82741, engine room relay block. Order PNC 82741 to
    get the short pin.
    Thank you.
    The Parts Technical Support Group"
    tcBob likes this.
  11. Jan 15, 2018 at 12:31 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    That is insane. I'd be scouring junk yards. Tacomas, Tundras... Anything late model. Good luck.
    DaManIam likes this.
