05+ Climate control back light and face color change
Discussion in 'Lighting' started by Jones, Feb 1, 2011.
  1. Feb 1, 2011 at 7:26 PM
    Jones
    Jones [OP] Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    2005 to 2011 Climate control back light and face color change to black
    Stock dials
    05 to 08 models
    09 to 11 with the Max A/C text – looks the same on the inside as the 05-08 one. This one has 9 blue rectangles and Max A/C text instead of a 10th blue rectangle. Under the Max A/C it is painted black to not let light in.
    Parts and Equipment list
    Climate control dials
    masking tape
    White spray paint
    Black spray paint
    Clear Matte or Flat spray paint
    Blue spray paint
    Red spray paint
    Adhesive inkjet vinyl sheets for the decals
    Hair dryer
    Exact-o knife or razor blades
    See here for taking it apart: http://www.tacomaworld.com/forum/lighting/106324-ac-controls-disassembly-pics.html There are 7 screws to take out.
    The silver and amber layers are a plastic type overlay that will just peel right off after the silver edges are detached from the black control dial body.
    Warning the silver dials are easily broken, if you plan to save them, take your time removing them.
    Make a cut around the silver and black area to separate the two.
    See this post for removable of the silver layer:
    http://www.tacomaworld.com/forum/li...back-light-face-color-change.html#post2701163
    Paint used:
    Print out temporary labels to cut out for painting the outlines.
    https://drive.google.com/file/d/1GEmnG3Ct6yD5GJtigbo6QjsQSPTQPtXK/view?usp=sharing
    Use a razor blade or exact-o to cut the outlines out. Scissors will work for everything except the blue and red area, the outline will be needed for painting.
    Before putting the blue dial label on to keep it from being painted, scrap of the black paint around the area where the max a/c text will be.
    Tape off all areas that do not need to be white:
    White paint layer for the icons
    After the white paint is completely dry, apply the icon cut outs over the white paint. Line up the shapes with the outlines under the white paint by shining light through the dials. Do not remove the labels for the red and blue areas.
    Black paint
    Red dial paint
    Peel off the label hiding the red dial’s area then use the dial outline to mask the black paint. Cover all other areas.
    Blue paint
    Painting finished, Peel off all the labels covering up the white areas.
    Ready for the vinyl:
    Vinyl print out
    Inkjet Clear Glossy Vinyl
    Updated to were to get the printable vinyl
    https://www.papilio.com/inkjet glossy clear transparent vinyl adhesive media.html
    Printer use: Cannon MG6120
    Files for printing in both Photoshop and in jpeg format.
    WITH Max A/C on the dial:
    Photoshop file
    https://drive.google.com/open?id=1oVnLgXeGJRRAV8Qt1bqYtZFEerODc3sP
    jpg file
    https://drive.google.com/open?id=11qq1aZosXIQxUFpb6-vdw71VG7Lf4_pz
    www.gimp.org is an open source program that is free that supports Photoshop files.
    Print out a test page to plain paper to make sure the scaling is correct before printing on the vinyl.
    After printing before installation:
    The instructions from Papilo/Texascaft were to use a laminate aerosol, I use good old matte clear spray paint, to seal it up and take the gloss out. The spray didn’t stop the vinyl from stretching when heated up.
    Installing the new dial decals:
    Trim the clear vinyl out to make the dial’s shape. These will be larger than the dials themselves but you need it to cover the edges.
    Putting the decal on the dials:
    • Pill away the backing to the adhesive decal.
    • Hold the dials up to the light to align the icon’s background and the decal.
    • Use the hair drier to form the vinyl to the front of the dials, taking out the wrinkles and any bubbles,
    • After the front is installed:
      • Heat the vinyl up as you do this part.
      • On the inside part of the dial, make small cuts in the vinyl but not where you will see it after the knobs are on. This is so you can stick the vinyl to the inside of the dials, were the knobs will go.
      • Now stretch the vinyl around the outside edges. Smooth it out as much as possible by stretching the vinyl out and getting it to stick the outside of the dial.
    • I put a rubber band around the dials to keep pressure on the vinyl, while it cooled down and the adhesive set in.
    I also sprayed matte clear spray paint afterwards to give it a finished smooth look.
    A/C and Air recirculation button
    I followed m3zy6 write up for changing the button’s color. Thank you for posting it.
    http://www.tacomaworld.com/forum/lighting/106431-my-ac-controls-light-mod-how.html
    I added in the black vinyl to fit into the theme of all black and white.
    Light for the dials
    http://www.oznium.com/corvette-c5-led 2 of these to go in place of the stock ones. They are powered with a (+) and (-) side, if they do not light up when first put in, back out and rotate 180 degrees and put back in
    The twists LED are a close fit, not exact but close enough to stay in. They can be made out of the current twist bulb with a 5mm LED and a 470ohm resistor.
    Since the LED's are 120 viewing angle, that doesn’t exactly cover all the little light tunnels to get to all the icons. I added in aluminum foil to reflect the light right. Before it is basically pointing straight forward and not towards the light tunnels.
    Selector knobs- replacing the amber inserts
    The hard way:
    Take EasyMold and make molds of the amber inserts, then make casts with EasyCast clear epoxy. Then lightly spray paint the outside with white paint
    The easy way:
    Clear hot glue works to replace the amber inserts. Tape off the front side to get a smooth finish, and add the hot glue in from the back side. Try to get the least amount of hot glue in there to keep light being cut down.
    Front side triangles
    Add a little white spray paint dabbed on the outside to show up during the daytime
    Finished product
  2. Feb 5, 2011 at 5:39 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Nice Job
    Thanks for the Write-Up
  3. Feb 6, 2011 at 1:32 PM
    Jones
    Texas DFW
    Changing the A/C dials from being back-lite with amber to white isn't impossible.
    Start with disassembling everything.
    Then where the silver outer cover needs to be separated from black body of the dials.
    Cut around the outside and inside where the silver meets the black plastic.
    The inside can be trimmed out a little bit to help with the next step.
    The silver outer cover is glued to the black plastic, and will need to be worked apart with something thin and strong. I used an end of a zip-tie. Do this on top and on the sides where the silver is. Do not stretch the silver to much or it will tear or stay deformed.
    All done removing the silver outer covers of the dials.
    Scrap the amber paint off the silver layer from the backside. Try to use a wide blade to not leave little scratches in the clear plastic.
    Lightly paint the backside in a thin layer of white paint. This is mainly for contrast on the front side with the silver and to make it look like the radio's buttons.
    The A/C and recirculation buttons, take acetone/nail polish remover and a q-tip to dissolve and clean off the amber paint.
    Add in LED lights, I recommend these from Oznium Link
    To get the light to shin evenly, I added tin foil for the lights to reflect to the light frame inside the dials. The foil needs to attach to the plastic dials then put the clear plastic light tunnels in before reassembling the electronics and backing together.
    Reassembly
    Daves300 likes this.
  4. Feb 6, 2011 at 1:37 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Wow. Nice job. That's a lot of work!
  5. Feb 7, 2011 at 2:57 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Man, that looks like a pain in the @ss. But looks to be worth the trouble because the end result looks killer!
    Did you do anything to mod the lighting of your gauges too?
    The stock amber panel lighting is one thing I've never been a fan of with Tacos in general -- there's something cheap looking about it.
  6. Feb 7, 2011 at 4:35 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    A lot of work just to have VDub interior... looks cool, though.
  7. Feb 7, 2011 at 4:44 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Subbed
  8. Feb 7, 2011 at 4:56 PM
    Jones
    Texas DFW
    I changed everything. Gauges, auto on the window switch, steering wheel controls, radio, and the clock( picked up an 09+ with LEDs on ebay).
  9. Feb 10, 2011 at 10:11 PM
    BenWA
    Boston burbs
    Good call on the VW look -- I was just thinking that it looks like the lighting in my buddy's Jetta.
  10. Feb 10, 2011 at 10:11 PM
    BenWA
    Boston burbs
    Do you have pix of the gauges?
  11. Mar 5, 2011 at 7:18 AM
    Jones
    Texas DFW
    Sorry I missed this, I would have replied sooner but I over looked it.
    Here ya go.
    Anyone giving this a shot out there?
  12. Mar 5, 2011 at 8:56 AM
    Cape Codder
    Jack
    Beautiful Job !
    Only thing keepin' me from doin' it is Time, Ability, and Fear :ballchain:
    CC
    theolee and McDudesYota like this.
  13. Mar 7, 2011 at 6:25 PM
    esizzle777
    esizzle777 Son of Most High
    Laredo, TX
    16 TRD Sport
    IF you're ever in laredo hit me up id love to get this done
  14. Mar 7, 2011 at 6:36 PM
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
    damn thats alot of work but job well done i want to do it but thats alot of work to change it so ima leave it be
  15. Jun 12, 2011 at 1:46 PM
    10.21 Well-Known Member
    Dillon
    North Carolina
    Black V6 Sport
    BHLM, Satoshi, Remove Mud Flaps, Debadge.
    Jones, do you have a write or link to the light changes? I've seen dash but nothing for the digital clock, radio, etc...would much appreciate it.
  16. Jun 12, 2011 at 3:17 PM
    Jones
    Texas DFW
    I have some links saved over time.
    Digital clock for 2009+, not really a write up but it shows the pieces. It is very similar to the LCD on the odometer.
    http://www.tacomaworld.com/forum/lighting/87534-2010-clock-lcd-led-backlight.html
    and the air bag, seat belt
    http://www.tacomaworld.com/forum/lighting/106431-my-ac-controls-light-mod-how.html#post2036191
    Stock head unit from an 05 to 09 radio, it is close to the same as the 10+ radio with a few more LEDs.
    http://www.toyotanation.com/forum/t184748.html
    Steering wheel controls
    http://www.toyotanation.com/forum/showthread.php?t=225203&highlight=steering+wheel+leds
  17. Jul 26, 2011 at 1:37 PM
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    How difficult would it be to just change color of the lights in the HVAC? I wanted to go blue but was told it can't be done because the amber paper is sandwiched in there. would I have to go through all of those steps just to change the color or would it be a lot simpler than I was told?
  18. Jul 26, 2011 at 5:02 PM
    Jones
    Texas DFW
    No other simpler way that I can image. The amber layer is to close to the top or outside of the dials, taking the amber layer out from the backside is not possible. The amber layer is directly under the silver paint and it doesn't take much sanding to get to it. Luckily the amber layer is not all the way through the dials and can be taken off.
    Keeping the silver color of the dials should be possible, you just have to print the black parts in silver and then leave the white spray paint step out. Maybe a light coat of the VHT night shade for tail light tinting could be used to create the dark background for the icons and letters but still let the light in when the lights are on.
  19. Aug 16, 2011 at 2:58 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    OP, the link to DL the template no work??
  20. Aug 16, 2011 at 3:07 PM
    Jones
    Texas DFW
    I will fix it as soon I get back to my computer
