0430 and 0420 code hell. :D FIXED!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jaab, Dec 20, 2015.
  1. Dec 20, 2015 at 6:17 AM
    Jaab
    Jaab [OP] Well-Known Member
    Captain Wiggles
    SW Ontario
    2005 Double cab short box 4x4 TRD Taco....
    OME 887, Dakars ARB bull Bar, M8000 winch,ABS mod, Locker mod, fog lights anytime mod, COMFY BMW sport seats, tweaked Airbag emulator,
    Posting here simply because I searched here a ton when looking for a fix and found lots of good dirt..... this is the fix I did, with great success. This fix should probably be tried first, before cats are changed, just to see if it works. Hope I am not being a pain in the ass. Its early and I am only on my first coffee/beer.
    I have been through hell and back with 0430 and 0420 codes and have figured out what I needed to do...quite the learning curve.
    First, I went to a reputable aftermarket cat. cost about $450 Canadian for the two...a hell of a lot cheaper that Toyotas. I e-tested. Failed.
    Then bought all 4 o2 sensors. E-tested. failed. Then I researched the living crap out of everything, went to my Toyota dealer to ask their thoughts and learned a few things.
    Using these figures as mythical ones merely for illustration...but hopefully the point will get across.
    Toyota Cats....90-95% efficient.
    Aftermarket Cats....80-85% efficient.
    The difference is enough to send the Toyota ECM into fits, spurting out codes of cat failure.
    So, amazingly enough, Toyota gave me the same fix I read about elsewhere.
    SPARK PLUG ANTIFOULERS. $6.00 (18mm, I believe)
    Take the antifouler and bore it out to a minimum of 1/2".....uninstall the downstream o2 sensor, reinstall the o2 sensor into the anifouler, then screw the assembly into the o2 bung....tighten, no silicone, just the supplied crush washers....reset everything, go through a complete drive cycle and baddaboom! CODES GONE!
    This took me a month of resetting, waiting for parts, installing and CRAP. The worst is going through drive-cycles...time consuming.
    DO NOT bore less than 1/2". It WILL set off the code again. Also...if for some strange reason this doesn't work...do not panic...STACK two antifoulers!!
    I really hope this saves a bit of time and worry for some...I live in an emission tested area and it sucks when you can't get those codes gone!
    now...amusingly enough, I am about to go to the garage and bore out another set for my buddy with the same issue. :D
    Revelations, 4WDTrout and chiefO like this.
  2. Dec 20, 2015 at 7:50 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I thought I knew everything - this is so embarrassing - what is anifouler ?? Where is it ?? Pics would be great - I googled anifouler and found stuff for boats. Again Pics would be great. Thanks for any help.
  3. Dec 20, 2015 at 8:20 AM
    Jaab
    Captain Wiggles
    SW Ontario
    Don't feel bad....kinda made me think of muffler bearings.... I will take a few before and after pics in an hour or so and post them here. :) Gotta go get a new reamer. :D
  4. Dec 20, 2015 at 9:00 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    Here is my collection haha. It's basically just a spacer for the o2 sensors. They also make them with 90° bends for tight places. Worked like a charm on my Lexus with Invidia mid-pipe.
    Jaab[OP] likes this.
  5. Dec 20, 2015 at 9:02 AM
    redzmvt
    redzmvt Well-Known Member
    Scott
    Western Wisc.
    2011 Regular Cab 4x4 Auto stock
    Bone stock for now
    Used these on oil-burners years ago.
  6. Dec 20, 2015 at 9:06 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Any more detail on the boring? Do all brands need boring?
  7. Dec 20, 2015 at 11:03 AM
    Jaab
    Captain Wiggles
    SW Ontario
    Lol....the help ones are one's I had picked up. I'm pretty sure they all need to be bored out. As spark plug anti fouler they require a much smaller hole. attached is a picture of before and after they are bored 1/2 inch.
    Crap. On my phone. One sec.
  8. Dec 20, 2015 at 11:12 AM
    Jaab
    Captain Wiggles
    SW Ontario
    I could fricking paint this picture and mail it faster than I can figure out how to post it...
  9. Dec 20, 2015 at 11:42 AM
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    Thanks for the information Jaab ! I'm not having any issues but this is good to know, however my dad is with his Camry. I've changed both of his sensors and turned the light of for awhile but it comes back on, I'll try this.
    Thanks for your diligence.
  10. Dec 20, 2015 at 11:57 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This is still just fooling the computer into thinking you fixed the problem. Check your fuel pressure.
    Even now check your fuel pressure and compare it to what is called for. I battled with this issue and fixed it correctly. The o2 readings are just a consequence of the real problem and the anti foulers are just masking that.
    4WDTrout and Jaab[OP] like this.
  11. Dec 20, 2015 at 12:13 PM
    tinker2
    @Sandman, what solved your issue, new fuel pump ?
  12. Dec 20, 2015 at 2:20 PM
    Jaab
    Captain Wiggles
    SW Ontario
    Yes....but if the only thing being fooled is the ecm into thinking it has the ultra-efficient toyota cat....well, I am OK with that.
  13. Dec 20, 2015 at 2:23 PM
    Jaab
    Captain Wiggles
    SW Ontario
    There are tons of potentials that would lead to these codes...this fixed mine. And my truck gets great mileage and has perfect power.
    This worked for me....all I'm saying
  14. Dec 20, 2015 at 3:26 PM
    george3
    New Jersey
    Thanks for your reply and work. Glad it wasn't lumped in with a muffler bearing or a flux capacitor. As an aside - one time I had one of those chain muffler shops change a o2 sensor and then had to have a real mechanic change it again later on. This info might come in handy and save $$. Thanks again.
  15. Dec 20, 2015 at 7:42 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Yes... IF..
    That's great but the problem is NOT fixed . Check your fuel pressure and we can compare real numbers. You have merely bypassed a symptom.
    12TRDTacoma and DirtJumper14 like this.
  16. Dec 20, 2015 at 7:45 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    I desperately urge anyone with this issue to check their fuel pressure before applying a blind solution. It's an inexpensive, quick, and easy diagnostic tool. #themoreyouknow
    12TRDTacoma likes this.
  17. Dec 20, 2015 at 7:46 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Correct, URD USA walbro255 plus I added an in line filter.
  18. Dec 20, 2015 at 7:48 PM
    Sandman614
    Tim
    '06 SR5 Off Road
  19. Dec 20, 2015 at 7:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interesting. A bad fuel pump is creating bad cat converter issues for people, it doesn't surprise me because you are essentially making the engine run overly lean due to the lack of fuel being supplied to the engine. In the same respect it doesn't surprise me because if you guys who have never done the fuel pump on these trucks before have ever seen what it looks like before, it's ridiculously small. Like so much to the point where I am surprised it is able to keep up with the demands of the engine in general. My 2012's pump failed in less than 50K just to give you an idea of how bad these are. Made by Denso at that. I don't know where they went wrong with these.
  20. Dec 20, 2015 at 7:56 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    For reference
