04 Transmission fluid change
Discussion in '1st Gen. Tacomas (1995-2004)' started by p.fist, Aug 11, 2015.
  1. Aug 11, 2015 at 11:00 AM
    p.fist
    p.fist [OP] Active Member
    04 regular cab 4x4
    So my truck now has hit its 100k mark and i wanted to give the transmission some attention seeing how it has never been serviced. I called my local dealerahip to get an opinion on a tranny service and i got the usual..." we only do flushes at an astronomical price speech" so forget that idea. I contacted my trusted mechanic and toyota owner, and he basically told me if i want to freshen things up just to do drain and fill... I think 4 quarts of valvoline max life.
    Any opinions would be great.
  2. Aug 11, 2015 at 11:07 AM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    I would check the owner's manual for recommended type and amount, if you have one that is. Otherwise search around the forum. I don't know if you're running manual or auto, but my auto takes only 2.1q on a drain/fill per the owner's manual.
  3. Aug 11, 2015 at 11:13 AM
    p.fist
    04 regular cab 4x4
    It's a 2.7l 4x4 4 speed auto. I have the owners manual i may have just misheard him when he was explaining. I've searched around seen a little bit here and there on the subject...doesnt look like anybody has had any issues. I just figured i would get it straight rather than read other peoples posts.
  4. Aug 11, 2015 at 12:36 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    get two gallons of Valvoline max life full synthetic tranny fluid and this is how you can flush the tranny yourself for free.
    under the radiator there are two rubber hoses for the tranny oil cooler lines in the radiator, you disconnect one of them and let it hang down to drain into the pan. don't worry about making a mess because it doesn't come out under pressure so its just going to dribble out. now one hose is an "in" hose and the other is an "out" hose so fluid may come out the hose or the open nipple in the radiator. I find it helps to add a short hose onto the line so its easier to direct the fluid coming out into the pan so it doesn't get on the front end parts there.
    now add about 4 quarts of tranny fluid to the dip stick, start the truck for 20-30 seconds or until the fluid flow stops coming out then turn of engine and add 4 more quarts of fluid. repeat until you see clean fresh fluid coming out and at that point, reconnect the hose and measure to refill to the correct level. if you put too much just open the hose again to pump some out.
    this method safely uses your tranny oil pump to pump fluid through the entire system so it replaces all the fluid everywhere even in the lines.
  5. Aug 11, 2015 at 7:08 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I bought a case of fluid from the dealership and do a drain and refill every other oil change or so.. My fluid looks new.....150,000 miles.
  6. Aug 12, 2015 at 1:14 PM
    p.fist
    04 regular cab 4x4
    I think i will start doing that. Did the drain and fill today, fluid looks great. Thanks for the input guys.
  7. Aug 12, 2015 at 1:19 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    I just changed my transmission fluid a month ago (3.4L though). The dip stick should tell you the type of fluid that is required. I stuck with the OEM Toyota transmission fluid for mine (Toyota ATF Type T-IV for my 3.4L 2003). It looked like Toyota switched between a few types of fluids in the early 2000s so make sure to check it out. The dipstick said that changing the fluid was not necessary under normal conditions (summarizing). It looked brown and nasty though (about 150K) so I bought the OEM fluid on Amazon and replaced it. I didn't pull the pan off to change the filter, but it looks so much better now.
    Edit: See you just posted that you changed it. Does the 2.7L take about 2 quarts?
  8. Aug 12, 2015 at 3:35 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    How many quarts was a drain and fill? My truck is pretty much like yours. 03 double cab, 150k, 3.4L. dipstick says type T-IV. I was planning to drain and fill. I want to say it is suppose to be about 3 quarts but want to make sure.
  9. Aug 29, 2015 at 10:05 AM
    KaBar
    KaBar Well-Known Member
    East Coast
    04 TRD SR5 4x4
    ARB bullbar, Total Chaos UCA, OME 881, Wheeler 5 leaf, Bilstein 5100s, custom TRD skidplate, All Pro rocksliders w/ fill plate, Tundra brake upgrade.
    How many times do you usually have to do this before the fluid starts to come out clean?
  10. Aug 29, 2015 at 12:22 PM
    keakar
    karl
    louisiana
    you will use about 1.75-2 gallons total for a tranny flush because the tranny holds about 6-7 quarts total if its all replaced or after a rebuild and you will waste a little of it of course.
    now looking at that, you can see how a simple drain pan and refill with 2-2 1/2 quarts of fluid isn't really going to do a lot to replace the old fliud but does more to get you a half and half blend mixture of old worn out fluid, mixed together with fresh new fluid. doing it that way is better then nothing at all but a drain pan and refill does more to give it a nicer looking color fluid then to get the old worn out fluid out of it and replaced.
  11. Aug 29, 2015 at 5:51 PM
    1985 4runner
    1985 4runner Member
    Gulfport, Mississippi
    02 Prerunner DC
    I just changed mine today on a '02 double cab 2.7. Dipstick said Dextron II, Manual said 2 quarts, as did the parts store where I bought my filter. Drained fluid measured almost 4 quarts. So I went back and bought two more quarts. After changing the filter & gasket 2 quarts barely registered on the dipstick. 4 quarts measured low when hot.
  12. Aug 30, 2015 at 8:21 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    When I flushed mine it took about 14 quarts to completely flush out all of the old fluid. Now I have brand new Toyota Type 4 in it. Yes I have one I've the machines that oil change places have. My Dad is a mechanic.
    Aagill225 likes this.
