02 Tacoma Running 33s ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stgenyoda, Jul 11, 2016.
  1. Jul 11, 2016 at 7:39 PM
    1stgenyoda
    1stgenyoda [OP] Member
    I'm looking at a 2002 Tacoma with the 2.7 auto and factory 4.56 gears. If I buy it I want to be able to run 305/70/16s on aftermarket wheels. Obviously i will need a lift...how much lift? Recommendations of a certain lift kit ? Also, will I need to regear ? Thanks
  2. Jul 11, 2016 at 7:52 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
    Google the "pinch weld mod" you're going to rub the fenders and or frame.
    What are your goals for the truck? Pavement princess, off road toy, dd or some combination of those?
  3. Jul 11, 2016 at 7:54 PM
    1stgenyoda
    This will be a daily driver, will see a very limited amount of off road.
  4. Jul 11, 2016 at 8:02 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    I'm running 285/75r16's and after doing the pinch weld mod i dont rub the inner fender but i do rub the frame at full lock when i turn left or right.
    Lift won't help you clear the frame or the fenders when the suspension articulates or you turn hard.
  5. Jul 11, 2016 at 8:09 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Gonna shamelessly promote some shocks I'm selling while in here. I just took off a set of OME nitrocharger sports with 880 coils and top plate spacers. They have less than 10k miles on them. :anonymous: they would give you some lift over stock, not sure how much. Your 2.7is lighter than my 3.4 and im 4wd (more weight up front)
  6. Jul 11, 2016 at 8:10 PM
    1stgenyoda
    Looked up the mod you mentioned seems pretty cut n dry. I would prefer not to lift the truck if I don't have to. I like the wells to look full....
    Hope to secure the truck this weekend. I already have a set of wheels and tires in the shop so hopefully I can get her all setup shortly after getting her home.
    Adventurer_Alex likes this.
  7. Jul 11, 2016 at 8:12 PM
    1stgenyoda
    I'll keep the shocks in mind. Good chance I'll want to do some more mods once I get her in my possession.
  8. Jul 11, 2016 at 8:14 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Heres mine with a light tube bumper, ome nitrocharger sports, 880's and 3/4in coil spacers up front. The rear has nitrochargers and ome dakar leaf springs.
    Tires are 285/75r16's
  9. Jul 12, 2016 at 4:27 AM
    1stgenyoda
    That looks sweet!
  10. Jul 14, 2016 at 1:22 PM
    codymac
    codymac Member
    homer georgia
    4x4
    I run 33/12.50r15 with 2" leveling kit no run but when complete lock off wheels and was hitting top A arm but setting the wheels out with dif wheel or spacer your good
  11. Jul 14, 2016 at 1:24 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Here's mine on 33 12.50s. I cleared about the same on 2" but its on 3" now. No change really.
  12. Jul 14, 2016 at 1:29 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    I got a 4wd 2.7 auto with 4.56 gears. If yours is a Prerunner, it'll be a little better cause I got extra gears to turn, but my truck is a dog and it's on load range c 31s. Those tires are gonna suck
  13. Jul 14, 2016 at 1:30 PM
    smmarine
    Melbourne FL
    I'm not going bigger tires till I get my supercharger and header on
  14. Jul 14, 2016 at 4:50 PM
    codymac
    codymac Member
    homer georgia
    4x4
    Nothing on the back?
  15. Jul 14, 2016 at 5:20 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I've got 1.5" add a leafs and took the overloads out so it'd sit level. But I ran the same setup on just 2" up front
  16. Jul 14, 2016 at 5:23 PM
    codymac
    codymac Member
    homer georgia
    4x4
    Yea I got just 2 up front now yours looks good though
  17. Jul 14, 2016 at 5:25 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    What brand bumpers do you have front/rear?
  18. Jul 14, 2016 at 5:34 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Appreciate it. Looking back, wish I just stuck with it but I've used that little bit of extra flex
  19. Jul 14, 2016 at 5:36 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Some guys have cleared 33's with no lift at all, they obviously would of had to cut quite a bit but if you dont want to lift thats something to keep in mind...id recomend a 2 or 2.5 inch lift though and just do the light trimming/cutting/bashing of that stupid pinch weld and that lil bit of plastic that covers the weld. As for frame rub youre gunna want to get 3.5 or 3.75 inch back space wheels to clear. If running a 12.5" wide tire im not sure if a 4" BS will clear or not, it would be very close. I personally run 12.5's on a 3.5" BS wheel and am nowhere near the frame, not even close. But in your case being more of a DD youre gunna pry wanna keep your BS a lil higher(bigger number) more in the 3.75 to 4 inch range, keeping your stance a lil narrower while still keeping from rubbing the dang frame!
  20. Jul 14, 2016 at 6:06 PM
    Adventurer_Alex
    Alex
    AZ
    2013 Nissan XTERRA
    Front is sketchy garage fab from craigslist and the rear is made by AVID. Its a 1 off with a hidden hitch and raised about 2 inches to be flush with the bed since i don't have a tailgate.
