02 TACOMA Inner & Outer Tail Lamp Screws ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by POLISHTACO, Feb 9, 2019.
  1. Feb 9, 2019 at 5:54 AM
    POLISHTACO
    POLISHTACO [OP] Well-Known Member
    Frank
    Connecticut
    2002 Tacoma sr5,2.7,manual,4x4
    Good Morning,
    Mr Tail Lamp covers on my 02 Tacoma have had the phillips heads stripped out from the years of use. I would like to replace them all while I'm still able to remove them. Toyota has the (longer)outer screws # 81519-87010 available nothing listed for the (shorter)inner screws? Does any one know of any interchange screws that will work? Thanks for your time
  2. Feb 9, 2019 at 6:55 AM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I’d just run to the hardware store and try a few sizes. It just needs to hold a few lb of plastic.
    Taco critter likes this.
  3. Feb 9, 2019 at 8:28 AM
    POLISHTACO
    Frank
    Connecticut
    I tried my local Homedepot and the screw heads where too large in diameter.
  4. Feb 9, 2019 at 8:44 AM
    POLISHTACO
    Frank
    Connecticut
    Thanks I'll have to double check my Homedepot
  5. Feb 9, 2019 at 9:13 AM
    exminnesotaboy
    exminnesotaboy Well-Known Member
    Maple Grove, MN
    01 Tacoma 4x4 V6 SR5 TRD Xtra Cab
    Bilstein 5100's / OME 881's / Wheelers 5 leaf pack / Level8 MK6/ 265/75-16 Bridgestone Dueler tires
    Order extra of the available longer screws and cut them down. If I remember correctly the head/diameter were same size.
  6. Feb 9, 2019 at 9:16 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I put security torx on mine. Don't want anybody stealing my red/clear TLs. I have extras. I'll sell you a set if interested but you need.to biy your own security torx bit if you don't have it already.
  7. Feb 10, 2019 at 9:49 AM
    POLISHTACO
    Frank
    Connecticut
    Will, Thanks for the offer on the security torx screws. I'm still looking for the phillips head in stainless,otherwise I might consider the security torx. I checked Homedepot today but the head is too large in diameter on the stainless screws they have. The oem screw head is approx 17/64" What is the head diameter on those security torx screws? Thanks, Frank
  8. Feb 11, 2019 at 4:04 PM
    POLISHTACO
    Frank
    Connecticut
    Thanks for all your advice. I ordered the (4) longer ones from Toyota and found some Gm taillight screws in my stash that where the same as the shorter ones . I'm good to go.
    Madjik_Man and Taco critter like this.
  9. Jul 25, 2023 at 7:40 PM
    Chadley22
    Chadley22 Well-Known Member
    Chad
    Tacoma
    I was also needing a couple of these for my 1st gen Tacoma.
    I was able to fine these at RK, they're almost exactly the same, just have a Torx head instead of phillips. )They were in the 'license plate' hardware bin.)
    Madjik_Man likes this.
