02 Sensor Replacement Issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bpriestley04, May 2, 2021.
  1. May 2, 2021 at 5:55 PM
    bpriestley04
    bpriestley04 [OP] Member
    2005 Toyota Tacoma 4 Cylinder - Manual Transmission
    Hey guys, I'm new here and looking for some advice. My 2005 Tacoma was running pretty smooth and then I had a check engine light come on. I took it to the local parts store who hooked it to the computer and found is had a bad 02 sensor in bank 1 slot 1. I researched and found that it was the upstream sensor, so I ordered one on Amazon. I replaced the sensor and the truck has been running fine however the check engine light would not go off. I decided to unhook my battery and let it set for about 5 minutes to clear the light. After I plugged it back up and started the engine the check engine light was off, but now my truck has a very low idle and eventually dies if I don't give it gas - and the check engine light is back on. Any advice on what I could do to fix this?
  2. May 2, 2021 at 10:07 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Run for codes again
    Did sensors get banged around while out!
    Check wiring
    Can’t see having to do a idle reset after that
  3. May 3, 2021 at 5:58 AM
    bpriestley04
    Thanks for the reply Greeves, the sensor didn't get banged around, and the wiring looks good. I will take it this evening and see what codes it pulls this time. This morning the truck didn't die on me, but it is still rough when idling.
    Thanks!
  4. May 3, 2021 at 6:01 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    A bad o2 sensor code rarely means a bad o2 sensor, cleaning the maf sensor usually is my first step just to check.
    It could be a dozen different things.
    Also I'd always recommend denso sensors for toyotas, I have a friend with a Camry who was always trying aftermarket ones, he switched ordering denso and it works much better. Pretty penny though.
  5. May 3, 2021 at 6:28 AM
    bpriestley04
    Thanks Werewolf, I'll try cleaning the MAF sensor and see if that helps.
  6. May 3, 2021 at 6:51 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Clean your throttle body, it's probably dirty. Disconnecting the battery resets the learned idle position of the throttle body and would cause a low idle/stalling if it's dirty untill it is cleaned or it relearns itself.
  7. May 3, 2021 at 11:08 AM
    Nick1999
    Nick1999 Well-Known Member
    Arizona
    2004 Red Tacoma S Runner
    No
    Amazon is not a good idea to buy sensors. You need to buy original Toyota O2 sensor from Toyota Parts Store in your location. I believe that you have a good OBD II Scanner, if not - then you need one - ACTRON Elite Auto Scanner CP9185, $71.99.
  8. May 3, 2021 at 6:11 PM
    bpriestley04
    Well, took it back to the auto parts store today. The code came back up as o2 sensor 1 bank 1. I did the idle reset and the truck is running much better now but the check engine light keeps coming on almost as soon as it's reset. I hate to spend $178 on an oem sensor if it's not even what is wrong with the truck. Not real sure what the MAF sensor is or where it's located, any help on that please?
  9. May 3, 2021 at 6:14 PM
    Bishop84
    Bishop84 Well-Known Member
    Which code is it?
    The reason the truck is idling low is due to carbon on the throttle body, the truck has to re-learn the idle and the carbon build up makes it take longer.
  10. May 3, 2021 at 7:15 PM
    bpriestley04
    I took a pic of the computer
  11. May 3, 2021 at 7:26 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you checked the A/F Heater fuse and relay in the engine compartment fuse box?
  12. May 3, 2021 at 7:31 PM
    bpriestley04
    I have not, but will do it first thing in the morning. Thanks!
  13. May 3, 2021 at 9:09 PM
    Waasheem
    Waasheem
    2007 xrunner
  14. May 3, 2021 at 10:59 PM
    Nick1999
    Arizona
    No
    A Mass Air Flow sensor (MAF) is one of the key components of an electronic fuel injection system in your car. It is installed between the air filter and the intake manifold of the engine. The mass air flow sensor measures the amount of air entering the engine or the air flow. You need to buy MAF Sensor Cleaner from your local auto parts store, then take the sensor off and spray the wire until is clear from carbon deposits. Clean the trouble code and start the engine. If again you have the same code, then you need to spend $178 for a OEM sensor....you get what you pay for.
  15. May 3, 2021 at 11:11 PM
    Nick1999
    Arizona
    No
    JPro likes this.
  16. May 3, 2021 at 11:24 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Same code I had. Looked up correct O2 sensor here. https://densoautoparts.com/find-my-part.aspx#searchResults
    Replaced it and CIL has been off ever since. Nov. 2020
    I know I have an 04 3.4V6 but thought this might help
    Good luck!
  17. May 3, 2021 at 11:42 PM
    JPro
    JPro Member
    Well, take it to the dealer and get to the bottom of it fast. I know it costs $$$, but I want mine fixed yesterday!
  18. May 4, 2021 at 11:42 AM
    Nick1999
    Arizona
    No
    You had P0031, HO2S - Heater control Circuit Low (Bank 1, sensor 1) and most likely solution is - replace O2 sensor. Yes, but not always. "most likely" and "Low" means that could be Catalytic Converter goes bad, bad gaskets, loose clamps, MAF sensor.
    6 gearT444E likes this.
  19. May 4, 2021 at 5:34 PM
    Waasheem
    Waasheem
    2007 xrunner
    Best answer.
    Tightening clamps is free. Crc maf sensor cleaner is cheap, unless you mess up and damage the sensor. Start there.
  20. May 5, 2021 at 9:32 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The A/F heater fuse and relay are common between both banks so I'd not suspect those as the cause, but you can measure the ohms of the bank 1 sensor 1 A/F sensor to verify it's in spec. If that check's out and your MAF is clean and reading good, you can also put a clamp on meter around the heater circuit B+ wire to measure the current, should be 0.8 amps DC minimum, do this with engine cold.
    Dm93 likes this.
