'02 5vze-fe fuel injector replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacowaco, Dec 8, 2020.
  1. Dec 8, 2020 at 9:24 AM
    Tacowaco
    Tacowaco [OP] Well-Known Member
    Tallahassee, FL
    02 Tacoma Double Cab 4x4
    My truck is a '02, not sure why I typed '04 in the title. I was chasing a cylinder misfire issue and decided to service the injectors when I noticed the o-rings appeared weak. I followed Timmy's youtube guide for the most part ( https://www.youtube.com/watch?v=N-lhZIWOkyU&t=1754s ) but thought i'd provide some comments. I would do an initial watch through and make notes of things he had forgot and added at the end of the video when getting access was more difficult. Also, I did not remove the throttle body. I would recommend having the new plenum gaskets, you can see in my pic that the old ones have parts peeling off. The old injectors were pretty dirty and some contamination was getting through the seals. I used my torque wrench on everything but the hard to reach fuel rail bolts, even Timmy's solution was not going to provide the correct torque ( if you alter the length of the torque wrench you need to use a formula to calculate the effective torque correction ) so I used what felt like 25 ft lbs. I also checked and found these aluminum washers (50 pack) that work fine on the fuel rail bolts:
    https://www.mcmaster.com/aluminum-sealing-washers/system-of-measurement~metric/
    part number 97725A104
    I used a special needle nose vacuum attachment to suck all the sand/leaves/crap from the intake area. Also a good time to check your hoses for cracks.
    I did use the Timmy recommended reconditioned injectors and they work fine. Also a good time to clean and dielectric grease your electrical connections.
    Digiratus likes this.
  2. Dec 8, 2020 at 10:50 AM
    Tacowaco
    Tallahassee, FL
  3. Dec 8, 2020 at 11:38 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I just did this a little while ago as well.
    Apparently I didn’t do the best job at it.
    I started getting a CEL P0171 ...lean condition bank 1.
    This is frequently caused by a vacuum leak.
    I bought a smoke machine from eBay for $64 and hooked it up to the brake booster hose.
    The leak was coming out of the injector for cyl #5.
    Looks like I’ll be taking that side apart and putting new seals in...again.
  4. Dec 8, 2020 at 11:43 AM
    Tacowaco
    Tallahassee, FL
    Do you think the injector bore was not clean? Also they said to turn the injector to ensure the o-ring didn't bind up. Good luck with your issue.
  5. Dec 8, 2020 at 11:45 AM
    otis24
    Mark
    California
    I think it’s not clean. It was super dirty and I vacuumed and swabbed it with a q tip thing.
    It turned ok.
    I did have one on the driver side that when I turned it there was a lot of resistance. I removed the fuel rail again to find the o-ring cut from getting bound.
  6. Dec 8, 2020 at 12:57 PM
    Tacowaco
    Tallahassee, FL
    I have one of those Harbor Freight nitrile o-ring kits and it has a whole row that matched the injector o-ring size.
    otis24 likes this.
  7. Dec 8, 2020 at 1:01 PM
    otis24
    Mark
    California
    That is good to know. Thanks!
  8. Oct 4, 2021 at 9:50 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I just did this last weekend, and once things were back together, and I started it, there was a large fuel leak. :censored: So I've got some more o rings, and planning on replacing them this week.
    Question though: The MotorWest injectors (Denso blue) come with a small packet of Super Lube. The Timmy videos detail dipping the injectors in gas before inserting them, but the inclusion of super lube seems to indicate that MotorWest suggests using that rather than the gas. Given how annoying it is to get down the to the fuel rails, I really don't want to do this wrong again. Thoughts on the super lube vs gas while installing the injectors?
  9. Oct 4, 2021 at 10:14 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    You can edit that thread title. Go to Thread Tools (upper right) and select Edit Title.
    Tacowaco[QUOTED][OP] likes this.
  10. Oct 4, 2021 at 12:07 PM
    Glamisman
    Glamisman Well-Known Member
    the tip on one of the injectors appears to be burnt. 3rd from the left in the cardboard box. anything "special" going on in that cylinder?
  11. Oct 18, 2021 at 10:32 AM
    Tacowaco
    Tallahassee, FL
    I think the whole issue was from chinese fake ngk plugs that mimicked oem. I didn't mind changing the injectors since they were dirty and had some contamination seeping into the rubber gaskets. It has run fine since replacing the plugs.
