01 tacoma can i run 32 w/ no lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jroach321, May 28, 2008.
  1. May 28, 2008 at 7:15 PM
    jroach321
    jroach321 [OP] Member
    Chattanooga
    01 TAcoma 4x4 white
    :DI was curious whether or not i can run 32's (255/75/17) on my 01 xcab 4x4 without rubbing. If not- what is the biggest tire?
  2. May 28, 2008 at 7:30 PM
    01TacoTRD
    01TacoTRD Carolina Alliance: Quack Addict
    Chapel Hill, NC
    2001 Tacoma TRD 5 spd. 3.4 ltr white
    holy s*** dude! read my thread i just posted above urs. I'm wondering the exact same thing. My 01 taco needs some new shoes and I was wondering what I could get away with as far as tire size without adding a lift
  3. May 28, 2008 at 7:38 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Hey there guys! I had 265/75/R16's on my truck before the lift, and had no problems.
  4. May 28, 2008 at 7:40 PM
    01TacoTRD
    Chapel Hill, NC
    evertaco, do you know what the biggest tire you can get away with is?
  5. May 28, 2008 at 8:38 PM
    ETaco23
    Evan
    PNW
    with the 3" lift or not?
    With my 3" lift, im maxed out at 285/75r16, with some slight trimming.
  6. May 30, 2008 at 4:21 AM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    We will find out soon... they will be in monday and i will throw it on the lift and find out. Thnks for the help
  7. May 30, 2008 at 4:33 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    With no lift you'd rub on 255/75's.
  8. May 30, 2008 at 5:13 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Depends on whether or not your willing to [​IMG]
  9. May 30, 2008 at 5:16 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    ^^^true on that.:D
  10. May 30, 2008 at 9:13 AM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    I have a plasma cutter! I would rather not lift it since its my daily driver. Cant have it rubbing though. I will probably put tundra coils in the front and ome leafs in the rear.
  11. May 30, 2008 at 10:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Gawd I hate metric sizes....
    For what its worth - many moons ago... I had a 96 tacoma with 32x11.50x15's on stock 15x7 wheels with only 1.5" of lift (no rubbing).
  12. May 30, 2008 at 3:35 PM
    Malcolm3.4
    Malcolm3.4 Well-Known Member
    Houston, Texas
    02 DBLCB TRD
    Rims and BFG AT 265/70/17 Homemade shackle mounts
    I have an 02 dbl cab with 265/70/17 (measure 32 1/2") that rubbed a little on the plastic covering the the pinch weld seam. I simple cut the plastic out with a utility knife and bent the pinchweld over to gain some extra clearence. The look on the tire shops guys was priceless:laugh: check out my pics.
  13. May 30, 2008 at 5:39 PM
    sstewart777
    sstewart777 Member
    Maine
    00 SR5 2.7
    Wow! What did that do to your power on take off and your MPG?
  14. May 30, 2008 at 6:02 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    +1 you've got my curiosity too
  15. May 30, 2008 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    265/70/17 is actually a 31.6" tire. You shouldnt notice a difference in mpg or in power as the increase is lesss than 5% over stock. :)
  16. May 30, 2008 at 6:26 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    so he's basically getting the same size tire....why bother?
  17. May 30, 2008 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    He's going from a 31" tire to a 32" tire. Its bigger, just not enough to affect the gearing or to adversly affect the milage. :) FWIW as tires are meassured, a 31.3 is considered a 32" tire, and so forth. They round up the size.
  18. May 30, 2008 at 6:46 PM
    ETaco23
    Evan
    PNW
    Like I said beefore, I had 265/75's with no problems! there was no rubbing, and thats the largest you can run, stock! On the 1st gen.
  19. May 31, 2008 at 5:54 PM
    Malcolm3.4
    Houston, Texas
    02 DBLCB TRD
    My 265/70/17 bfg ats measured 32 1/2" when brand new. The stock 265/75/16 they replaced measured 31". There wasn't any loss in power, still smokes the tires. MPG wasn't really affected, 22 mpg to 21 1/2 mpg. Ride comfort was alittle affected due to running higher air pressure to handle more weight. I currently run around 45 psi compared to 35 on the stockers. The tread wear on bfg at is incredible. Ones on my 02 4runner lasted close to 60,000 miles and still passed inspection.
  20. Jun 2, 2008 at 7:00 PM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    Ok guys- mounted the tires today! (08 TAcoma SR5 17's with BFG Mud-Terrains 255/75 r17) No rub except at full turn. I did trim the front valence a little, altough it still looks factory. They look great. Will post pics ASAP.
