01-04 headlight adjustment?
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrianPK, May 6, 2008.
  1. May 6, 2008 at 12:05 AM
    BrianPK
    BrianPK [OP] Offroad Enthusiast
    Modesto, California
    01 TRD 4WD V6 SR5
    CB Radio, 3'' fabtec spacer lift and 3'' body lift flowmaster dual exhaust, deckplate mod, silencer mod, Work in progress pioneer 7900bt stereo with 5X8 infinity speakers all around, and eclipse ex400 amp
    does anyone know how to adjust the headlights on the 01?
    my truck has a 6in lift, and i can't go anywhere without blinding someone... (running silverstar platinum bulbs) really bright
    Nate3265 likes this.
  2. May 6, 2008 at 5:10 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    ... And here's a diagram for the location of the adjustment screw thingie (driver's side illustrated)....
    Amandavei82, AJ1001 and Nate3265 like this.
  3. May 6, 2008 at 5:12 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    On mine it is a hex head on the end of a threaded rod, found at the lower outside end on the back of each light housing. Use a 4.5mm wrench. It only adjusts up and down. There is a bit of side to side that you get during the up/down however
  4. May 6, 2008 at 5:14 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    - get the truck on a level surface facing a vertical wall
    - mark on the wall the level / line directly in front of the headlight bulb / center (i.e., @ same vertical height as headlight)
    - back the truck away from the wall to a distance of 3 meters (9.84 feet) from the wall surface to the headlights
    - turn on low beams
    - the low beams should hit the wall 20.9 mm (0.823 in.) _below_ the line @ headlamp height (based on designed 4 degree low beam downward deflection from horizontal)
    - use the vertical adjuster bolt / screw to make this so
    This should work on any model, because the spec is relative to horizontal from lamp center, not distance from the ground. Hope this answered well:)
  5. Apr 10, 2009 at 3:33 PM
    skip56
    skip56 New Member
    Fortuna, CA
    2001 Extended cab
    Thanks for the informative post Ridgrunner! It was exactly what I was looking for. Now I need to find a 4.5mm socket. I have everything from 5mm-24mm. Porbably gonna be hard to find a single 4.5mm.....
    Thaanks again,
    Skip56
  6. May 10, 2010 at 6:47 PM
    emglishe30
    emglishe30 Well-Known Member
    NJ
    2010 SR5 Base 4x4 DCSB
    Pioneer Touch Screen, Sub, Diode Dynamics SS3 Sport amber fogs, Oem skid plate, led accent lights, led 3rd brake, 2011 color matched honeycomb grill. Plasti dipped pieces.
    I've been looking everywhere for this thanks...
  7. Nov 26, 2011 at 5:58 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I just did this last weekend. Used a 1/4" drive, 4 mm socket. It fit perfectly.
  8. Nov 28, 2011 at 7:38 PM
    scocar
    scocar hypotenoper
    Me too. Shoould have done it right after the lift. :anonymous:
    FSM pages attached for technical goodness.
    Taco Phil likes this.
  9. Jan 27, 2012 at 4:08 AM
    Afraz
    Afraz Well-Known Member
    Toronto
    03 Double Cab TRD
    Projector H.I.D
    I have aftermarket Projector headlights that do not have the small plastic thing which you slide the side lights into. Is it possible to remove this plastic thingy from stock headlights and mount them to the after market ones, to ensure a better fit between after market headlights and side lights ?
    Because right now my side lights kind of just stick out.
  10. Jan 27, 2012 at 4:15 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
  11. Oct 13, 2015 at 7:15 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Which way do you turn the socket to raise the lights? Right up left down?
  12. Oct 14, 2015 at 9:26 AM
    scocar
    scocar hypotenoper
    You'll find out pretty quickly if you follow the instructions I posted from the FSM above.
  13. Oct 14, 2015 at 10:15 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I already got them adjusted. I have retrofits so I had to get the projector cut off just right. I had normal HID's before with stock housings and it was spraying light everywhere so I had lowered them but now I had to raise them back up. I couldn't even see 5 feet in front of me at night but when no cars were coming I would just turn on my 42" light bar for my hi lights!
  14. Dec 16, 2018 at 2:32 AM
    Glenn54
    Glenn54 Active Member
    Glenn
    Upper Marlboro, Maryland
    SR5 4X4
    (2001 Tacoma 4x4, ext cab, 2Dr). Happy holidays to all. Thought I'd wake this thread from the dead with a quick question. I recently replaced my faded headlights with Depo brand. When adjusting the aim from 9.8 ft away, I notice the lighting is defused with a solid bright spot in the center. Is the solid bright spot what I should be looking at to align proper height?
    DanK83 likes this.
