01-04 Flares on 98-00
Discussion in '1st Gen. Tacomas (1995-2004)' started by Willbeck, Sep 16, 2015.
  1. Sep 16, 2015 at 9:53 AM
    Willbeck
    Willbeck [OP] Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    So I like the flares for the first gen prerunner and 4x4 trucks, but my 2000 obviously doesn't have the holes in the fenders to mount them.
    Is there anyone here that has installed 01-04 flares on a previous year first gen? I was thinking of just using 3m tape where the clips would normally go, and just the normal bolts inside the fender well.
    Also, does anyone know he part # for the rubber trim that goes against the body? I was able to pull it intact with the flares, I'm just not sure how much longer they're good for, and may as well replace them.
    Thanks!
  2. Sep 16, 2015 at 9:55 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Or you could switch out to other fenders that do have the holes.
  3. Sep 16, 2015 at 10:21 AM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    I would have to track down silver fenders, and that could be an expensive pain. Got the flares off a truck with front end damage ask a bad frame.
  4. Sep 16, 2015 at 10:26 AM
    TashcomerTexas
    I've seen unpainted fenders go for around $50 I think. Color match paint cans cost around $10, nothing too expensive.
  5. Sep 16, 2015 at 10:27 AM
    TashcomerTexas
  6. Sep 16, 2015 at 10:31 AM
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    If I had to I could, but then I would need bedsides too. Rattlecan can come out nice, but if the 3m double sided tape works, I'd rather not have holes in my fenders lol.
    4 fenders @ $60ish is $240, plus shipping, which on bedsides could be crazy expensive, plus primer, paint, etc... Could be a $500 project very quickly.
  7. Sep 16, 2015 at 11:21 AM
    TashcomerTexas
    Ah, thought you meant just the front fenders. Anyhow I doubt 3m tape will last to the elements, and speed bumps etc. so good luck on that.
  8. Sep 16, 2015 at 11:30 AM
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
  9. Sep 16, 2015 at 12:02 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    I realise u already have the flares, but if u come across any bushwhacker extenda fender flares they don't utilize the holes in the fender but utilize screws from the underneath lip and fasten to the wheel well. They look virtually identical to the OEM's.
    Something to maybe think about....u can pry order the rubber trim pieces from them too if ya can't find any elsewhere...
  10. Sep 16, 2015 at 4:55 PM
    Madjik_Man
    Colorado Front Range
    Don't know what the 01-04 flares are like but if they have the lip that goes under/into the wheel well, why not just drill holes so you can bolt them on ala a 98-00 flare?
  11. Sep 16, 2015 at 5:01 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My 2004 has the front end from a '98. The driver side fender is from the '98. It was a non flared vehicle. I opted to use the non flared fender in place of any aftermarket fenders because the factory fenders are very superior to aftermarket fenders.
    Because of this, I figured I was going to have to drill holes to mount the flare. I never got around to doing it. There are enough screws on the underside of the flare to hold it in place just fine. Its been like that for 25,000 miles. I doubt I'll ever drill those holes and properly mount the flare.
    Willbeck[OP] likes this.
  12. Sep 16, 2015 at 5:57 PM
    bry838
    oregon
    Ahh yes!! Perfect idea if they have the same lip!
