00' Coolant Specs
Discussion in '1st Gen. Tacomas (1995-2004)' started by ForumContributorsAreLife, Jun 9, 2017.
  1. Jun 9, 2017 at 1:14 PM
    ForumContributorsAreLife [OP] Well-Known Member
    I was looking through here, and see there are plenty of threads asking the same thing. But, it always ends up to discuss something unrelated to the questions, so I want to get this cleared up.
    Tacoma coolant.
    Which type? (OEM or is there an alternative)
    How much?
    Diluting?
  2. Jun 9, 2017 at 1:31 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    OEM Red, quantity depends on engine, 4WD or not, AT or MT? Check your manual in the back. Dilution is 50/50, unless you live where it's really cold. The guide for this is on the bottle. Note that prediluted OEM also exists but it's a rip off compared ot diluting with distilled water yourself.
    Note it's on Amazon, not a bad price, but might be lower elsewhere ($32). Search for
    Toyota Genuine Fluid 00272-1LLAC-01
    I know there is at least one "red" product that is supposed to be as good as OEM, it probably is. Many NAPA's carry it- Zerex Asian Vehicle. The premixed stuff is $16 on Amazon.
  3. Jun 9, 2017 at 8:42 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Some people are purists and say only Toyota Red because of the chemical make-up of the coolant having no silicates. Silicates are bad. Bad Silicates, BAD! Others, like me use Prestone Green and then others use a similar brand to Prestone.
    It's my opinion you're fine with Toyota Red or Prestone Green (or similar product). The key is to renew it regularly ( I do a drain and refill of the radiator every 30,000 miles). The big thing is doing a proper flush if you want to change to a different coolant. Mixing different coolants could cause a gelling effect which isn't good. So, you just drain the radiator, fill it up with distilled water, run the engine with the heater on high(rear too if you have a rear heater), drain it out again and repeat this process until what's coming out looks really clear. Then you drain it a final time and add your 50/50 mix. Also, don't forget to empty the overflow and refill that. Some bother to find the block drain and drain that too but it's my opinion that's a waste of time because you're not talking a whole lot that's left in the there. A guy on T4R.org showed what he drained out of the block and it looked like maybe 1 pint.
    Like Mike said above, a 50/50 mix is pretty standard. The capacity of the system is a little over 2 gallons. To make sure you can completely top off your system, either buy 3 gallons of a 50/50 mix, or buy 2 gallons of antifreeze concentrate and 2 gallons of distilled water.
    Here's a video in case somebody reading this thread wants to know of a technique to flush the cooling system on their rig.
    <iframe width="560" height="315" src="https://www.youtube.com/embed/oQsxmi-CNng" frameborder="0" allowfullscreen></iframe>
    Dalandser and lucky13don like this.
  4. Jun 10, 2017 at 11:40 AM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    I will say I just did the block drain and it's worth doing given the amount of crap that came out of it (particulates). You'll need about 24" of extensions to move it easily. I just put a masons tray (home depot) under that entire side of the truck and it caught everything. I "flushed" the block by putting some distilled water in my upper radiator hose after disconnecting from the radiator. This truck had a ix of red and green. They layered themselves in the engine/radiator, as the color changed as I drained. Just my opinion!
    Dalandser likes this.
  5. Aug 23, 2017 at 4:03 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Do you access it through the wheel opening?
  6. Aug 23, 2017 at 8:35 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    Yes, passenger side. You'll need to remove a couple of the plastic rivets to get the rubber flap out of the way. You'll want at least 12-18" of socket extensions to get in there. It's kind of hard to find but a flashlight helps!
