0 degree camber alignment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rybern, Feb 8, 2023.
  1. Feb 8, 2023 at 6:41 PM
    rybern
    rybern [OP] Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    I recently did a 1.5/1.5" lift via 4th perch via 5100's and 3AAL. Truck drove great but I got an alignment anyway and noticed that my front wheels had a slight visual positive camber(tilt outward at the top). I got out the laser level to confirm this and calculated that I had a half a degree or more of POSITIVE camber. This seemed really weird to me and I took it back to my alignment place(I've used them for over 20 years). It had a +.6 camber and +1 caster and was within factory specs. I told him I didn't like the idea of positive camber and asked if he would make it closer to 0. He obliged me and here's my new specs. Why would Toyota do a positive camber?
    Do my numbers seem OK? Truck drives great but being at the bottom end of specs is causing me to 2nd guess my request of 0 degree camber.
    Disregard the toe, the wheel was slightly turned when this pic was taken.
    HondaGM likes this.
  2. Feb 8, 2023 at 6:46 PM
    Bishop84
    Bishop84 Well-Known Member
    So the more camber you have the more caster you have, more caster is actually better than low camber.
    Toyota uses positive camber on their IFS trucks simply due to suspension variable load and off camber road use.
    Oddly though the 4runner specs are zero and they are nearly similar.
    I always say with lifted trucks and stock arms, you want at least 1.5 caster, and less than 1 degree of camber.
    If you want zero camber and more than 2 degrees of caster, you need aftermarket arms.
    1 degree of caster isn't enough for me. It rides much better the closer to 2 you can get.
    Edit: lastly it looks like you're running low toe as well, with bigger tires (assumed) it has outward force and causes negative toe. So I always bump it up a hair for 32s and 33s. Never ever zero.
    HondaGM likes this.
  3. Feb 8, 2023 at 6:49 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Not near enough caster… I would want more positive camber
  4. Feb 8, 2023 at 6:57 PM
    rybern
    N Alabama
    This is where he put after I asked for a little less camber. I kind of wish I'd left it here. Although I doubt I can tell the difference driving it.
    Bishop84 likes this.
  5. Feb 8, 2023 at 7:01 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    How much caster will you get with a half degree more camber?
  6. Feb 8, 2023 at 7:03 PM
    Rusty66
    Rhode Island
    That answers my question, that's a nice alignment.
  7. Feb 8, 2023 at 7:04 PM
    Bishop84
    This was more ideal, although I try to balance left and right a bit better.
    Either way, drive it, and if the tire wear is goofy, just get it re-aligned in a few months.
    Give them a reason to re-align it. Go offroading and bang aroud the new suspension.
    Rusty66 and HondaGM like this.
  8. Feb 8, 2023 at 7:20 PM
    rybern
    N Alabama
    I appreciate the response. It dives good to me.... it tracks straight down the road, the wheels wants to center itself at speed and coming out of a corner. I'm just trying to understand why Toyota recommends the positive camber(wheels not being perpendicular with the ground).... especially when you consider that tires normally wear on the outside edge. :notsure: I'd hate to be in that line of work and deal with people like me, lol. :oops:
    HondaGM likes this.
  9. Feb 8, 2023 at 7:22 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Angles change with travel …
  10. Feb 8, 2023 at 7:22 PM
    rybern
    N Alabama
    Also, he is willing to adjust to it again but I don't really have a reason to get him to do it.
  11. Feb 8, 2023 at 7:25 PM
    rybern
    N Alabama
    That makes sense but isn't the travel typically just like it is when the alignment is being done? I'm typically driving straight and not down a road with a bunch of suspension demands. I feel like I'm missing something.
    HondaGM[QUOTED] likes this.
