“Check engine” and “trac off” light on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Elite777, Mar 13, 2018.
  1. Mar 13, 2018 at 7:39 AM
    Elite777
    Elite777 [OP] Well-Known Member
    2015 4 banger MGM Access cab
    Here’s what I did.
    -Oil change
    -rear diff fluid change
    -throttle body cleaning
    -maf cleaning
    I now have a check engine light and trac off light showing up.
    I already disconnected the battery and reset the truck but the lights came back on. I’ve also checked the gas cap to see if it’s loose.
    Update...
    At the dealer
    Code found: P2441
    Bravisimo likes this.
  2. Mar 13, 2018 at 7:41 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Did you touch the sensor to the maf while cleaning it?
    And also go get the code read for the CEL
    Elite777[OP] likes this.
  3. Mar 13, 2018 at 7:48 AM
    Elite777
    My finger did touch the circled in red part.
    Other than that no. I use maf cleaner.
  4. Mar 13, 2018 at 7:50 AM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I had those exact same 2 lights come on in my truck the day after I bought it (new). They had to replace the ECM. It was bad. I would take it to the dealer if it is still under warranty.
    I did get an 8 year 100k warranty for my troubles, though.
    ready6delta and Elite777[OP] like this.
  5. Mar 13, 2018 at 1:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Get the code read and find out where the trouble area is. So far we have nothing to go on.
    Kyitty and Elite777[OP] like this.
  6. Mar 13, 2018 at 2:15 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Loose or bad gas cap,you then have too clear the code afterwards to make the light go out.Autozone will read and or clear the codes for free.
  7. Mar 13, 2018 at 5:27 PM
    Elite777
    P2441
    mabepossibly likes this.
  8. Mar 13, 2018 at 5:33 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Smog pump valve is stuck closed.
    tomwil likes this.
  9. Mar 13, 2018 at 7:08 PM
    Elite777
    How can I fix this ?
  10. Mar 13, 2018 at 7:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Call the dealer and ask of they already know about this. Ask if it is covered under warranty
  11. Mar 13, 2018 at 7:14 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  12. Mar 13, 2018 at 7:19 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    From what I understand they are covering this under warranty now.
  13. Mar 14, 2018 at 9:48 AM
    Elite777
    Any info on what caused this or how I can fix it
  14. Mar 14, 2018 at 10:40 AM
    koditten
    Kirk
    Central Michigan
    The thread listed above had references to how this part is changed.
    Did you check with having it repaired under warranty?
  15. Mar 14, 2018 at 10:45 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Are you new to the forum? There is a thread that details everything about the issue you are having
  16. Mar 14, 2018 at 5:09 PM
    Elite777
    No I’m not new sorry. Just click on my profile and It tells you when I joined the forum.
  17. Mar 14, 2018 at 5:11 PM
    Elite777
    truck is at the dealer as of now. I was hoping to not have to read through 23 pages of reply’s. I was just looking for some direct info about my code. I might be using the forum wrong tho.
  18. Mar 14, 2018 at 6:28 PM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    If it does turn out to be the infamous air injection valve/pump issue the linked post refers to - I know it's been a serious plague for the 2012's, although there have been reports of other 2nd gens having the issue. People came up with a number of work arounds, one being a bypass, another being replacement with Tundra valves. In January, Toyota finally acknowledged the problem and offered extended coverage for that issue. I'm not 100% sure if Toyota is covering it for all 2nd gens now, or just the 2012 models. I finally received a letter explaining the coverage a few weeks ago. Ironically I popped the codes Sunday night. Brought it to the dealer and they confirmed and ordered the parts. I believe they replace the valves, pump and pump cover. That's the short version of that thread.
    Also - When I brought it to the dealer, I was in limp mode with the trac and CEL on. I left it that way so they'd see it. They pulled it into the bay and about an hour later came out telling me they were ordering the parts.
  19. Mar 15, 2018 at 8:19 PM
    Elite777
    Thanks for the info. That was thorough.
    Got my truck back after the dealer kept it over night. They didn’t know why the secondary air pump stopped working. They cleared the code, “activated” the air pump and told me it was good.
    I for some reason think I will be back very shortly with the same problem.
  20. Mar 15, 2018 at 8:27 PM
    sioux
    Northern Minnesota
    2012 DCSB SR5 4x4
    The dealer cleared my codes Monday. It hasn’t re-tripped, but my parts came in and they’ll be replaced tomorrow. I know people have gone a variable length of time between having it re-trip. I’ll find my letter tomorrow and see if they specify the 2012 model year.
