“Braking Power Low” and other messages - Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by quickstop, Apr 13, 2024.
  1. Apr 13, 2024 at 10:50 AM
    quickstop
    quickstop [OP] Well-Known Member
    Kentucky
    2021 Tacoma Off-Road DCLB
    Has anyone else ever had this litany of messages pop up out of the blue? ABS, PCS, BSM, and “Braking Power Low” all came up and won’t go away after restarting the car, and cleaning the sensors. 2021 Tacoma. Paid off yesterday haha, gotta love the irony. Luckily it should still be under the initial warranty but I curious if anyone else has experienced this and it was something simple/stupid, or if it’s more of an involved issue. Brake fluid level looks fine too.
    - Truck is not lifted
  2. Apr 13, 2024 at 10:52 AM
    quickstop
    Kentucky
    Going to call the dealer about it on Monday but figured in the meantime I would do some research.
  3. Apr 13, 2024 at 11:01 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    have you messed with or replaced the grill and/or front sensor? If so, I would start there, especially if it's aftermarket.
    GL
  4. Apr 13, 2024 at 11:13 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    Unless I need eye exam, the last photo shows brake fluid level in reservoir angle.:oops:
  5. Apr 13, 2024 at 11:17 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Mice?
  6. Apr 13, 2024 at 12:06 PM
    protocol7
    protocol7 Active Member
    stinky
    I would also not rule out small rodent electrical damage. Had to get a sensor and harness replaced on my other vehicle just a few months ago because something chewed through an entire sensor cable.
  7. Apr 13, 2024 at 12:10 PM
    quickstop
    Kentucky
    Rodent damage is certainly possible, hate to say. I live out in the country and they are definitely on my property. Though, I did just notice a hairline crack on the front sensor and it is indeed an aftermarket grill, so I’m hoping that is it. Will order a replacement today.
    If it turns out to be neither the sensor nor the grill, any other ideas?
    Chew likes this.
  8. Apr 13, 2024 at 12:27 PM
    Kobe_lee24
    Kobe_lee24 Well-Known Member
    SOCAL
    2020 Tacoma TRD OR
    I once had a rat chew off my crankshaft sensor wire. And my car was throwing all kinds of lights and signals.
  9. Apr 13, 2024 at 12:51 PM
    quickstop
    Kentucky
    Replacement garnish ordered. Here’s to hoping it’s as simple as a $30 part.
    CrashZone and Kobe_lee24 like this.
  10. Apr 13, 2024 at 12:52 PM
    Kobe_lee24
    SOCAL
    2020 Tacoma TRD OR
    Good luck
  11. Apr 13, 2024 at 1:52 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    cracked sensor is definitely suspect.
    Also aftermarket garnish's are known to cause problems. I have read you may have to rig up your own spacers to properly align.
    quickstop[QUOTED][OP] likes this.
  12. Apr 13, 2024 at 2:06 PM
    quickstop
    Kentucky
    Hopefully not, I ordered the garnish from the same place I got the grill from, it seems like a simple plug and play. Fingers crossed.
  13. Apr 13, 2024 at 2:08 PM
    quickstop
    Kentucky
    To make the Taco jealous I gave my ‘96 T100 a bath right in front of it…better behave Taco, better behave. The T100 is a little time machine. I miss when vehicles were simple. IMG_4800.jpg IMG_4804.jpg
    JSX, RustyGreen and Chew like this.
  14. Apr 26, 2024 at 7:20 AM
    quickstop
    Kentucky
    Replaced garnish in the grill, that did not fix it. Took it to dealer and after a few days poking around at it, they determined it was both a bad wheel speed sensor *and* wheel speed sensor wire on the front driver’s side. Thankfully it is covered under warranty so they are doing everything at no cost. Unfortunately the wire is back ordered for a month so it’ll be awhile to get it fixed. Bringing the truck home where it’ll be more secure than in a dealer lot for that long. Will update when part comes in and this is hopefully fixed.
    Rednecktacoma22 and Chew like this.
  15. Apr 26, 2024 at 9:43 AM
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2019 TRD-OR AC
    Nice, that's an easy fix.
    Wire probably snagged something and ripped, or a furry critter had a snack.
    Cheap fix regardless, w.o warranty.
