Tacoma Won't Start?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jonesey441, Dec 9, 2020.
  1. Dec 9, 2020 at 7:44 PM
    jonesey441
    jonesey441 [OP] New Member
    2018 ACLB TRD Sport Cement
    I had an interesting experience this weekend with my 2018 TRD Sport. When I tried to start it, nothing happened. There was no sound of the engine trying to turn over or anything. All the electrical worked fine, lights, radio, basic accessory mode stuff. There were also two error messages on the screen saying "Check charging system" and "Check brake system".
    After troubleshooting the basics - dead battery, blown fuse, dead key fob - a passerby recommended (with fair warning that it's not an ideal solution) resetting the short term memory in the computer. I put it in "Ignition On" mode, disconnected both of the battery cables, and touched them together, then reconnected. The truck was able to start after that.
    However when I turned the truck off and let it sit for a few minutes the same thing happened, and the same solution worked. I brought it to my local Toyota dealership and they diagnosed it as an issue with the after market remote start. I just purchased the truck a few days ago and didn't know it had it. Toyota will be removing the remote starter tomorrow.
    I simply wanted to post this in case anyone else ends up in the same situation. Hopefully this would save some headache.
    Kev250R, 911disp031 and Interbeing like this.
  2. Dec 9, 2020 at 7:47 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  3. Dec 9, 2020 at 7:49 PM
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    Take it back and get 05 to 2014 Tacoma problem fix
  4. Dec 9, 2020 at 7:54 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Yeah because no one ever put an aftermarket starter on one of those lumps that led to issues.
  5. Dec 9, 2020 at 7:55 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. Thanks for posting, I’m sure someone will benefit from this information. Most of the electrical issues posted on this forum are due to aftermarket mods.
    Kev250R, shakerhood and Dryfly24 like this.
  6. Dec 9, 2020 at 7:56 PM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
  7. Dec 9, 2020 at 8:16 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    Thanks for sharing. I posted in a different thread about having the same exact problem as you. It has only happened once so far and I did install a remote start about a month ago. I didn’t disconnect the battery though, I was able to lock and unlock the truck with the remote after a few minutes and the truck was able to start finally. When it happened to me I had started it with the remote and let it run, it shut of of course after opening the door, I figure I tried to start it too quick after and it wouldn’t. I got the same check charging system message also. My first thought was a problem with the remote start, but who knows. I’ll wait and seeing it happens again. Good luck
  8. Dec 9, 2020 at 9:32 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  9. Dec 9, 2020 at 9:39 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    Which aftermarket starter is it?
  10. Dec 9, 2020 at 9:39 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    Same question goes for you... which remote did you you install?
  11. Dec 9, 2020 at 11:08 PM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    I did alarm installs for a few years, and we got people towed in every day with starting problems. Most alarms are made in China under DEI group. the QC is very poor.
  12. Dec 10, 2020 at 6:28 AM
    jonesey441
    I'm not sure which remote start it was. I'm picking it up from Toyota hopefully today and will post back here when I find out.
    RangerComa[QUOTED] likes this.
  13. Jan 27, 2022 at 10:49 AM
    Gumpmann84
    Gumpmann84 Member
    Forrest
    Idaho
    Cement 2020, TRD OR, Long bed
    Roadmaster Active Suspension, Sumo Springs, ARE Camper w/ Yakima gutter pylons & bars and a Prinsu Cab Roof Rack.
    I had the same problem this morning. I don’t have an aftermarket remote start though. Just the regular key fob, press the lock three times then hold method. I let the truck warm up a bit then came out to load up gear and when I hit unlock it didn’t turn off, which was my first clue something was up. The other clue was that everything for the climate control was in max defrost; which is not how I left it. So I got into the driver seat and put my foot on the brake and pressed the start button. Everything shut off. Tried the regular starting procedure. All the systems come on. It goes right into max defrost for some reason. But the truck won’t start. No attempt to turn over; nothing.
    It does give me the error, sometimes, about the charging but not each time I try.
    It worked perfectly fine yesterday for my 40ish mile round trip drive.
    No luck, had to take my wife’s car….
  14. Jan 27, 2022 at 10:55 AM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Should have asked for help from a passerby..:rofl:
    vivid02 likes this.
  15. Jan 27, 2022 at 3:44 PM
    Tacomaryan18
    If you lock and unlock the doors with the the remote are you able to start it after that? Or even start again with the remote? Sometimes the system seems to get jammed or “confused” I run into this maybe once every few months.
  16. Jan 27, 2022 at 3:54 PM
    Montana_Actual
    Montana_Actual ;)
    44-16 Taco likes this.
  17. Jan 27, 2022 at 5:49 PM
    Gumpmann84
    Gumpmann84 Member
    Forrest
    Idaho
    Would have been more effective.
  18. Jan 27, 2022 at 5:50 PM
    Gumpmann84
    Gumpmann84 Member
    Forrest
    Idaho
    I tried unlocking the doors again. Locking them. Getting out. Tried the whole process again. Nothing worked.
  19. Jan 27, 2022 at 5:51 PM
    Gumpmann84
    Gumpmann84 Member
    Forrest
    Idaho
    And the update.
    Got home at the end of the day. Got in the truck and voila, starts right up….
  20. Jan 27, 2022 at 10:54 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    My money is on your battery going bad. Batteries fail in different ways and these trucks (along with most modern vehicles with lots of electronics) don't like fluctuations in Voltage; those fluctuations can cause some of the issues which you experienced.
    Getting a Load Test on your battery from a local Auto Parts store should tell you everything you need to know.
