Rear Bumper Plastic Piece
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jlleiber, May 9, 2011.
  1. May 9, 2011 at 4:32 PM
    jlleiber
    jlleiber [OP] Well-Known Member
    Justin
    Indiana
    2019 MGM TRD Sport DC 4x4
    I have done a search and found several people looking for what I am looking for but not many good options as to where to get it. I broke the plastic piece that sits on the step below the license plate on the rear bumper. Anybody know where I can get one of these?
    Looks like the piece in the pic below.
    2010 Tacoma Crew Cab Sport
    [​IMG][​IMG]
  2. May 9, 2011 at 5:00 PM
    jlleiber
    Justin
    Indiana
  3. Oct 9, 2011 at 8:13 AM
    kb1jop
    kb1jop kb1jop
    Rick
    Webster, MA
    2020 Magnetic Gray Metallic SR5 Double Cab
    Factory Towing Package OEM Bed Mat Hard Tonneau Tacoma All-Weather Floor Mats
    Searched and did not find anything about how difficult it is to take off and put a new one on. Any help would be appreciated. :confused:
  4. Oct 9, 2011 at 11:21 AM
    sdnicker2000
    sdnicker2000 Well-Known Member
    Nebraska
    Mostly Stock 08 TRD Sport
    Rear spring TSB, Fumoto Valve, No A/C on defrost mod., tailgate theft mod.
    I have been looking for just the caps (that cover the bolts and ball hole mount) as mine were stolen. No luck unless I want to spend $$$$$.
  5. Oct 9, 2011 at 12:10 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    I just took mine off and its super easy. 2 bolts and to push clips
  6. Oct 11, 2011 at 4:55 AM
    kb1jop
    kb1jop kb1jop
    Rick
    Webster, MA
    Are the bolts the ones under the caps so I need to remove them first? Or are there some other bolts underneath? Thanks.
  7. Oct 12, 2011 at 6:12 AM
    jlleiber
    Justin
    Indiana
    I attached a diagram....
    The two bolts you need to remove are on the underneath side (one toward each end) [90119-A0048 in the diagram] and the two clips are on the top side [52161-04010]. And the clips are under the two small square flaps [52169C] that you pop up with a flathead screwdriver. The bolts under the raised caps hold the rest of the bumper together and don't need to be removed. When removing mine I remember the clips being a pain in the a$$ and I broke them while trying to get them out. There's probably an easy way to remove the clips but I couldn't figure it out :rolleyes:
  8. Oct 12, 2011 at 6:20 AM
    kb1jop
    kb1jop kb1jop
    Rick
    Webster, MA
    Will be trying it this weekend. Hope all goes well.
  9. Oct 12, 2011 at 9:10 AM
    07TaCo07
    oregon
    For the clips use a small screw driver and pry the top part up and the bottom part will come out with it
  10. Oct 12, 2011 at 11:59 AM
    jlleiber
    Justin
    Indiana
    @sdnicker2000...I got my parts from Mike Howell at Toyota of Newnan. He gave me 30% off of standard dealer price and like $5 for s&h. You might want to shoot him an email at mikeh@toyotaofnewnan.com and see what price he can get the caps to you for. Based on the diagram in my earlier post, you'd need part 51997B if you have the towing package, or 52592 if you don't. Worth a shot.
  11. Oct 17, 2011 at 2:35 PM
    kb1jop
    kb1jop kb1jop
    Rick
    Webster, MA
    Sorry if it's overly detailed.
    Tools needed:
    - 10mm socket
    - Small putty knife
    - Small screwdriver
    - Small hammer
    - Flat-faced drive punch
    Removal:
    - Remove capscrews underneath bumper using 10mm socket
    - Gently pull up the square covers [52169C] on top using a putty knife
    - Getting under the washer ring, gently pry up the clips [52161-04010] using a small screwdriver [they are mostly plastic, so be careful not to be too rough]
    - Bumper piece [52159] should slide out towards you easily
    - Gently pop out bolt caps [51997B if you have the towing package, or 52592 if you don't] and center ball hole cover [52591A] being careful not to break the catches underneath them [they are somewhat flexible]
    Installation:
    - Install bolts caps and ball hole cover onto the new piece
    - Slide piece into place and replace capscrews underneath but don't tighten fully
    - Line up the clip holes with the holes in the bumper [you may have to press the piece in hard]
    - Gently tap the clips back in using a hammer and a flat-faced drive punch [didn't have one handy so I used a socket extension]
    - Replace square covers [press in by hand]
    - Tighten capscrews underneath and you're done
