4.0L 1GR 2nd Gen Oil Change Guide
Discussion in 'Technical Chat' started by chris4x4, Jul 8, 2008.
  1. Jul 8, 2008 at 4:53 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    (See 3.4L 5VZ 1st Gen oil change for 1st Gen Tacomas)
    The oil filter for the 2.7 second gen is: 90915-YZZG1 (the following part numbers are equivalent:
    90915-YZZG1, 08922-02011, 90915-YZZD1, 90915-YZZD1-DS)
    Oil filter for the 4.0 second gen is: 90915-YZZD3
    Make sure you have all you need for your Oil Change:
    Oil filter
    Oil filter wrench
    New oil plug gasket (available from dealer)
    5.5 quarts of oil
    5/16" ID 5ft long tube
    14mm socket wrench
    Oil pan
    Oil funnel
    Remove the plug at the bottom of the filter holder:
    Connect a 5/16" 5 foot long tube to the filter drain, and run it to your Oil catch pan. Alternatively, you can try a method @Plain Jane Taco posted about here:
    "I just took a plastic cup (a slim one), put a couple of holes in the rim and attached a small bungee cord to it. When your done carefully lift it out and dump it. Throw the cup away or clean it out and use it next time." 2 pics below:
    Using a filter wrench, remove the filter:
    Clean the filter mount to get the dirty oil that sleft in it, out.:
    Put the filter holder plug back on. Lube the new filter seal with a light film of oil:
    Install the new filter. Hand tight, then 1/4 turn:
    Get a 14mm socket, and find the Oil drain plug under the truck:
    After breaking it loose, remove it and let the oil drain out:
    After the Oil drains out, with a new gasket on the drain plug, reinstall the plug in the Oil pan and torque to 30 lb-ft:
    Then, Fill with 5.5 Quarts of your favorite oil:
    Run the engine for a couple of mins. and check the level:
    Dont forget to recycle your used motor oil.
    Many Auto parts store will accept your used motor oil for recycling. Check your phone book.
    :D
  2. Jul 8, 2008 at 5:06 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    what size is the filter cap remover
  3. Jul 8, 2008 at 5:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I cant remember.....:eek:
    I have a set, and its the medium one. :D
    Joe Anthony Sanchez likes this.
  4. Jul 8, 2008 at 7:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    BUMP. I think this is a good idea. :)
  5. Jul 8, 2008 at 7:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think ita a good idea too. we should make this a sticky!!
    Beauxdon likes this.
  6. Jul 8, 2008 at 7:50 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Crap.. that's how the oil comes out of that resevior... I used the 'ol soak it up with a rag technique.. (no wise a*s remarks please...)..
    Also just picked up a craftsman oil filter adapter that adapts to various sized filters..
  7. Jul 14, 2008 at 8:31 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Thanks for the info about the plug at the bottom of the filter holder. I have not change my oil yet since I only have 1,100 miles. I never knew that was there thanks for the info.
    TacomaCZman likes this.
  8. Oct 14, 2008 at 11:51 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    This would be a good sticky
  9. Oct 14, 2008 at 12:23 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    running a tube to the bottom of the filter holder is a good idea...I just coverd the thing with a plastic wal mart bag...free...easy...
    Rambo54 likes this.
  10. Oct 14, 2008 at 12:48 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    agreed. I have just been using a 16oz water bottle, but still end up spilling it some times, going to get some tubing for the next time for sure! Bump for Sticky or for other people.
    lee4x4 and Rambo54 like this.
  11. Oct 14, 2008 at 1:20 PM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    Good idea - great thread - STICKY!!
    P.S. You could add to it with info on oil types and selection as well as filter selection etc...
    Malinosan and Fight4Function like this.
  12. Oct 15, 2008 at 5:39 PM
    Flyguy
    Flyguy New Member
    :confused:As you face the oil drain plug on your back ,as your feet extend out from under the front grill ,It still is lefty Loise- rightie tighty right? Would really hate to strip that sucker.
  13. Oct 15, 2008 at 5:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep! If it helps, set the ratchet before turning the bolt, just to be safe. :)
  14. Oct 28, 2008 at 6:16 PM
    MT_mudflaps
    MT_mudflaps Just playin' on the runways
    Clint
    Bellflower, CA
    Indigo SR5 PreRunner with TRD off road
    I should've looked at this last night before I changed the oil for the first time -- oh well!
    Good post though!!!! I agree it should be sticky-fied!
  15. Oct 30, 2008 at 10:52 AM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar Toyo Open Country AT/3's Bilstein 5100's up front, (#2) & 4600 in rear Daily driver....
    Man, I sure wish my oil filter was that easy to get to! ( I have the 3.4) I like that little shield that is around the base of the filter.:thumbsup:
  16. Oct 30, 2008 at 11:12 AM
    DFPTaco
    DFPTaco It's TACO time!
    Josh
    Las Vegas, NV
    19 DC SB TRD OFF ROAD
    little lift, wheels and tires, prinsu rack, TRD Pro grille, some lights, and some scratches.
    Sweet, I didn't know about the filter drain thingy. That'll save a mess in the future...
  17. Oct 30, 2008 at 11:12 AM
    DFPTaco
    Josh
    Las Vegas, NV
    Anybody know the part numbers for the larger size mobile 1 oil filter???
    Rambo54 likes this.
  18. Oct 30, 2008 at 11:24 AM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    I made a huge mess when i changed my oil last month...I never knew that little plug was under the filter...I did what raycie did...I had to mop it up with paper towels and rags...
    See....You learn something new every day...
    TacomaCZman and gugman like this.
  19. Nov 3, 2008 at 9:44 PM
    perniva1978
    perniva1978 Active Member
    Fort Worth TX
    04 PreRunner V6 Double Cab
    Bridgetone Dueler Alenza
    I used to do my own oil changes since I was in high school (1994) until I got to own my 2004 Tacoma V6. I did 1 oil change and then I gave up. It's too uncomfortable. Looks like your pictures are for a 4-cylinder Tacoma and it might be easier than changing the oil on a V6.
  20. Nov 4, 2008 at 4:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Welcome to Tacoma WOrld! The pics are from the 1GR-FE V6. :)
    nikkerton likes this.
