2nd Gen Tips, Mods & More
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Mar 26, 2008.
  1. Mar 26, 2008 at 10:52 PM
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    Note: this post is a compilation of things that would otherwise be stickied in the 2nd gen thread. If you're looking for a thorough list of mods, check out the Tacoma mods (1st and 2nd gen) thread maintained by @piercedtiger.
    TSBs
    2010 Transmission TSB
    2009 Transmission TSB
    Check here for a list of all the available TSBs
    Check here to see if anyone has had the Suspension TSB performed in your area and what their experience was.
    4wd System Operation & Help Thread
    Common Problems
    -Steering Wheel Shake
    -Steering Wheel Shake 2
    -Steering Vibration Fix
    -Blower Motor Squeek Chirp Low Fix
    -Fan Speed Switch Not Working
    -Overhead Console Temp/Compass Fix
    -Squeaky Leaf Fix
    -DIY Fix your ticking engine
    Maintenance Tutorials
    -Maintenance Quick Reference Guide (tool sizes, fluids, maintenance intervals & more)
    -How to: drop, clean, and reinstall the 2nd Gen transmission pan and filter
    -Lower steering shaft rebuild
    -Wheel bearing seal and CV dust seal install tip
    -How to reset and calibrate your VSC computer - The Easy way
    -Changing the serpentine belt
    -Remove CV Axle and Replace Front Wheel Bearing
    -Front Diff Transfer Case Oil Change
    -Reset Maintenance Required Light
    -Cleaning the throttle body
    -Full Automatic Transmission Flush
    -Replace shifter indicator lamp
    -How to change tail lights
    -How to change third brake light
    -How to Drain/Refill Automatic Transmission
    -DIY Full Flush Automatic Transmission
    -DIY Front Brake Pad Change
    -UCAs Alignment
    -How to remove/install 1GR-FE alternator
    -Transfer Case oil change
    -Inside 05 Transfer Case
    Modifications
    -Hose clamp to reposition CV boot
    -RatioTek transmission upgrade
    -Big 3 wiring upgrade
    -Bobbing the truck bed for off-roading
    -Swapping 2012-2015 AC Controls into 2005-2011 Tacoma
    -Brake Upgrade: StopTech Rotors + TRD Performance Pads
    -A-Pillar RAM mount GPS/Phone holder
    -Center Console Organizer Mod
    -DIY Hi-Lift and Tool Bed Mounts
    -Removing amber from the clock display
    -Body mount bushing installation
    -DIY AirFlow Snorkel Install
    -DIY Painting Fenders
    -DIY Hand Throttle
    -DIY Homelink
    -Dual USB charging outlet install
    -DIY Lighted Glovebox
    -Installation and Removal of E-Locker 3rd Member
    -Daytime Running Lights
    -Sleeved fog light housing
    -Install Homelink Garage Opener
    -DIY Tailgate Lock
    -DIY Tailgate Lock 2 (advanced)
    -Installing side steps
    -Heated Mirrors
    -DIY Washable Cabin Air Filter
    -Tinting your tail lights
    -Installing a Toytec Lift Kit
    -Installing a Toytec Differential Drop
    -Leather Arm Rests
    -Non-OEM Foglights
    -Illuminated 4wd Switch
    -Secure Locking Gas Cap
    -Lights under the hood
    -Differential Breather Mod for Dummies by Neubs
    -Bed Mat Mod
    -Program OEM Wireless Remote
    -How to wire bed lights
    -Satoshi Grill Mod write-up
    -Beep on lock
    -Cheap Vehicle Tracking System
    -Remove/Replace Door Handles
    -USB Power Plug
    -Installing running boards
    -Pop N Lock install
    -How to Trim Mud Flaps
    -Installing HID lights
    -Remove Center Console
    -Oil Pan Heater Mod
    -Long Travel Information
    -Lifting Your Truck - Things you need to know
    -Change LEDs in the stock radio
    -Backlit Toyota Grill
    -Inexpensive Mirror Mount for GPS, Radar Detector, etc.
    -Headlight Removal
    -Snorkel on a Budget
    -Increase Approach Angle with Modified Skid and Bumper
    About Your Truck
    -List of sockets and wrenches for 2nd Gen Tacoma
    -Disable the Antilock Braking System (ABS)
    -Every Part # for your Ride
    -Toyota TRD Catalog
    -Drive Modes - Traction Control
    -1GR Info
    Show us your...
    -Taco
    -Taco - Take 2
    -Stereo
    -Stickers
    -Wet Okoles
    -Shell
    -Bumpers
    -Sliders
    Show us your Cab Styles
    -Double Cab Long Bed
    -Double Cab Long Bed - Take 2
    -Double Cab Short Bed
    -Access Cab
    Show us your Colors
    -Indigo Ink
    -Magnetic Grey Metallic
    -Timberland Mica
    -Pyrite Mica
    -Super White
    -Barcelona Red Metallic
    -Black Sand Pearl
    -Silver Streak Mica
    -Speedway Blue
    -Radiant Red
    -Impulse Red
    -Desert Sand
    -Blue Ribbon Metallic
    -Spruce Mica
    -Silver Sky Metallic
  2. Feb 24, 2010 at 10:08 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I opened this thread for link suggestions.
    sybiotesrage and tullulah14 like this.
  3. Feb 25, 2010 at 6:32 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    It's there, 7th one from the bottom going up.
    Contra4205 likes this.
  4. Feb 25, 2010 at 6:52 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Is there one for the "Backup Camera Anytime" "Switched Backup Camera" Mod?
  5. Feb 25, 2010 at 10:36 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    you can check the cheap tacoma mods thread, if it isn't there then you can provide me a link.
  6. Feb 25, 2010 at 12:05 PM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Hotrodroxie likes this.
  7. Mar 1, 2010 at 5:44 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I added some photo threads. Does anyone else have any favorite photo threads?
  8. Mar 7, 2010 at 6:23 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
  9. Mar 9, 2010 at 7:49 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
  10. Mar 10, 2010 at 4:36 AM
    dog tired
    NE Ohio
  11. Mar 23, 2010 at 6:10 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    my tires wub the front plastic when reversing. whats up with that?
    i just added spidertrax spacers also
  12. Mar 28, 2010 at 9:33 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
  13. Apr 1, 2010 at 12:21 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
  14. Apr 1, 2010 at 8:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  15. Apr 1, 2010 at 9:57 AM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
  16. Apr 17, 2010 at 8:55 AM
    justinhemler
    justinhemler New Member
    09 V6 Tacoma
    i just need to find where to order 09 factory fog lights.... any help?
  17. Apr 22, 2010 at 11:59 AM
    Peanut424
    Peanut424 Its not the speed that kills Its the sudden stops
    Eddie
    Dallas, GA
    2012 PreRunner 4Door
    2.5 bilstein 5100 lift, FN Fx pro wheels 17x9's (high gloss grey). Toyo open country rt's (33's). Softtopper, rock sliders, and alot more to come
    I got a little over $300 for my birthday, I want to go with a spacer lift for the yota but some people say if I lift it than I should do it right and do UCA and coils and yada yada. But seeing as how I'm impatient and don't want to keep saving money. Which way should I go? Cold air intake, exhaust, other mods. I'm clueless.
  18. May 3, 2010 at 6:11 AM
    Tacoma2010530
    Tacoma2010530 New Member
    Chico, CA
    2010 Double 4X4 TRD
    I have a 2010 Tacoma with the factory VSP alarm. It like to go off for no reason. Has anyone heard of this or know why? I know it is a 2010 and it is under warranty, however I like to do a little research before going to the dealer.
    Thanks,
  19. May 7, 2010 at 7:48 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
  20. May 14, 2010 at 1:31 PM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    I just ordered a set of Piaa 525 driving lights to go on my Smitty Bilt Bull Bar. they will be here next week.
    3coma likes this.
