1st Gen. "DIY" and "How To" Thread: Compiled list of helpful links
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, May 29, 2010.
  1. May 29, 2010 at 4:39 PM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Ive been saving these links to a .txt file for future reference. Its been growing and i figured I might as well share. If anyone has a link they want to share, Ill include it in this post. All (most) of these links helped me one way or another.
    Part Stores/websites:
    http://www.4wheelparts.com/
    http://www.autopartswarehouse.com/
    http://jsimotorsports.com/index.php/
    http://toyotapartszone.com/
    http://www.trdparts4u.com/scripts/default.asp
    STEERING/SUSPENSION:
    Aftermarket Wheel Fit Guide:
    http://web.archive.org/web/20081007213703/http://www.ttora.com/wiki/index.php/Tire_and_Wheel_Fitment
    Beginner's guide to lifting your truck:
    http://www.customtacos.com/tech/index.php?article=137
    FAQ for Lift (compiled list of help threads, etc...:
    http://www.tacomaterritory.com/forum/showthread.php?t=94262
    Suspension Front and Back:
    http://www.bajataco.com/Suspension.html
    Suspension Lift Install:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/55486-1st-gen-suspension-install.html
    Bilstein 5100 Install Thread:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/114418-bilstein-5100-install-thread.html
    http://www.tacomaworld.com/forum/su...djust-bilstein-5100-shock-during-install.html - 5100 Adjust-how-to
    DIY Heated Seats
    https://www.tacomaworld.com/threads/easy-diy-seat-warmers-heaters-with-45-ebay-kit.785152/
    Write up on all around suspension lift on the cheap:
    http://www.4x4wire.com/toyota/projects/blackbean/ome/
    Old Man Emu Suspension Article:
    http://fresh.tacomaterritory.com/wiki/index.php/OME
    UCA Install and Explanation Threads/links (some are 2nd gen but still applicable):
    http://bajataco.com/tech/control_arms_01.html -Remove/Replace stock UCA.
    http://spc-tv.com/install/lt-suv/69-25470-toyota-tacoma-upper-control-arms.html - LR UCA (2nd gen but similar to 1st)
    http://www.tacomaworld.com/forum/suspension/14507-total-chaos-uca-how-install.html - 2nd Gen UCA install (1st gen not much different)
    http://www.tacomaworld.com/forum/su...earance-driving-report-light-racing-ucas.html - Alignment write up (LR UCA - again, 2nd gen but still similar to 1st)
    Light Racing UCA Install Video for 1st Gen Tacoma's:
    http://www.youtube.com/watch?v=FL9iEqqRmS8&feature=player_profilepage
    Steering Bushing Replacement:
    http://parksoffroad.com/tacomamods/kristacoma/rackbushings/rackbushings.htm
    http://www.keystonekrawlers.com/Mods/Toyota/SteerBushing/TacomaSteeringBush.htm
    http://www.lieblweb.com/steeringbush.html
    http://forum.ih8mud.com/95-gen-toyota-trucks/412826-steering-rack-bushing-replacement.html
    http://www.yotatech.com/f2/steering-rack-bushing-replacement-169316/
    Steering Rack Guide Replacement: Inner/Outer Tie Rod Replacement:
    http://www.youtube.com/watch?v=AVQHgcXEhpE
    Upper/Lower Ball Joint Replacement: Rear Leaf Replacement:
    http://parksoffroad.com/tacomamods/lift/alcanrearsprings/alcan.htm
    Axle Wrap Fix:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/108316-goodbye-axle-wrap-mod.html
    2.5" Cornbred Spacer Lift:
    http://www.lieblweb.com/cornbredlift.html
    2.5" Daystart Spacer lift:
    http://www.lieblweb.com/daystarlift.html
    Rear Shock Relocate
    https://www.tacomaworld.com/threads/how-to-1st-gen-tacoma-rear-shock-relocate.540417/
    Thread on Steering Column Fix: (for loose/clunky steering)
    http://www.tacomaterritory.com/forum/showthread.php?t=11145
    Steering Column Fix Write up:
    1st Gen Emergency Brake Fix:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/44039-emergency-brake-fix.html#post754954
    Brake Wright ups (swaps/installs): - Great Tundra swap write up!
    http://www.customtacos.com/forum/showthread.php?t=76847&highlight=tundra+brake+conversion - Tacoma/Tundra brake swap
    http://www.tacomaworld.com/forum/1st...03-tacoma.html - Tacoma/Tundra brake swap discussion
    http://www.4wheeloffroad.com/techarticles/drivetrain/131_0708_4x4_disc_brakes/index.html - Brake swap/install help
    http://www.toyotaholics.com/support/topic.asp?TOPIC_ID=317 - Tundra brake install
    http://www.scribd.com/doc/58403789/Caliper-Upgrade-for-Early-Tundras - How to spot older Tundra calipers from newer larger calipers.
    Video on replacing pads and rotors:
    Part 1:
    http://www.youtube.com/watch?v=M7gEOMny5Dw
    Part 2:
    http://www.youtube.com/watch?v=Ov9V5BvNW7Q&feature=related
    Brake Line Mods for Lifted Trucks:
    http://www.bajataco.com/Brakes1.html
    CV Axle Replacement/CV Axle boot replacement:
    http://www.4x4wire.com/toyota/maintenance/cv_axle/
    http://www.customtacos.com/tech/index.php?article=113
    http://www.tacomaworld.com/forum/technical-chat/21192-how-change-cv-axle-01-04-add-tacoma.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/45268-replacement-cv-boots.html
    http://vimeo.com/3089355
    http://www.youtube.com/watch?v=5bTJRzrv4iA&feature=player_embedded
    ENGINE/TRANSMISSION/DRIVE TRAIN MAINTENANCE:
    Valve cover removal/Gasket Replacement:
    http://www.youtube.com/watch?v=IThNiZcs4bI&feature=player_embedded
    Valve Adjustment:
    http://www.yotatech.com/f128/5vz-fe-3rz-fe-2rz-fe-valve-adjustment-tech-226997/
    TRD Supercharger Build (4Runner 5VZ-FE):
    http://www.speedysgarage.net/sportrunner/
    Seafoam (clean carbon from engine, etc...):
    http://www.seafoamsales.com/how-to-use-sea-foam-motor-treatment.html#nogo - Generic
    http://www.tacomaworld.com/forum/1st-gen-tacomas/63790-seafoam.html - Tacoma Specific Thread
    Spark Plug Replacement:
    http://www.4runners.org/writeups/sparkplugs/
    http://www.ngksparkplugs.com/tech_support/spark_plugs/faqs/faqread.asp
    -Spark plug read-up. How to diagnose spark plug for engine troubleshooting:
    http://www.aa1car.com/library/cm1196.htm
    Spark Pluge Wire Replacement:
    http://www.tacomaworld.com/forum/1s...eplacing-spark-plugs-wires-5vz-fe-3-4-v6.html
    How to Change your belts:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/67346-1st-gen-how-change-your-belts-p-s-c-alternator-2-4-2-7l.html
    http://www.4x4wire.com/toyota/maintenance/timing_belt/
    http://www.yotatech.com/f2/how-change-drive-belts-3-4-l-5vz-fe-216234/
    Water Pump Replacement 3.4L:
    http://www.lieblweb.com/waterpump.html
    Idler Pulley Rebuild: Oxygen Sensor Replacement 3.4L:
    http://www.lieblweb.com/o2replacement.html
    http://autodiyonline.com/toyota-diy...-1995-2004-3-4l-oxygen-sensor-replacment-diy/
    Rear O2 Sensor Replacement:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/142451-rear-o2-sensor-done.html
    Clutch Pedal Bushing Replacement:
    http://www.lieblweb.com/clutchbushing.html
    Ebrake Adjustment:
    http://www.lieblweb.com/ebrakeadjustment.html
    2x4 to 4x4 Conversions: (auto 2x4 to manual 4x4) http://www.tacomaterritory.com/forum/showthread.php?t=27216
    2-Low Mod (4Lo but in 2WD):
    If you have a J-Shifter (not buttom/switch 4wd): If you have the buttom/switch: - Post 5
    Propeller Shaft Assembly Diagram (PDF): Zerks and Greese Fittings: http://www.4x4wire.com/toyota/maintenance/front_end/lube/
    http://www.tacomaworld.com/forum/1st-gen-tacomas/142481-greased-my-drive-shaft.html
    Front Wheel Bearing Replacement:
    http://www.tacomaworld.com/forum/wheels-tires/260188-changing-out-wheel-bearing-how.html
    Rear Axle End (drum brakes) Seal Replacement: Rebuild Aisin Locking hubs:
    http://forum.ih8mud.com/79-95-toyot...ng-aisin-locking-hub-locking-hub-rebuild.html
    E-Locker Rebuild/Troubleshoot: http://www.tacomaterritory.com/forum/showthread.php?t=7433&highlight=locker+motor+pictures
    http://www.tacomaworld.com/forum/1s...locker-will-not-engage-bad-actuator-help.html
    3.4L Oil Change How To:
    http://www.tacomaworld.com/forum/technical-chat/48136-oil-change-how-3-4-5vz.html
    Transmission Oil Change:
    http://www.gadgetonline.com/TransFlush.htm
    http://www.ehow.com/how_6634137_change-fluid-2003-toyota-tacoma.html
    Automatic Transmission FAQ, Troubleshooting, and guides, etc....(A340):
    http://www.pirate4x4.com/forum/showthread.php?t=587521
    http://personal.utulsa.edu/~nathan-buchanan/93fsm/autotrans.html
    Synthetic Oil Recommendations and Torque specs for T-Case, Tranny, and Differentials:
    http://www.tacomaworld.com/forum/at...and-vs-competition-amsoil-recommendations.pdf
    Thread on Synthetic Oil GL-4 vs GL-5:
    http://www.yotatech.com/f116/gl-4-vs-gl-5-a-201741/
    Differential Oil Change:
    http://www.tacomaworld.com/forum/2n...ront-diff-transfer-case-oil-change-howto.html
    http://www.tacomaworld.com/forum/technical-chat/24545-changing-differential-fluid-step-step-how.html
    http://www.toyotanation.com/forum/1492885-post37.html
    Oil Cooler Install:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/108470-hayden-transmission-oil-cooler-install.html
    Fuel Filter Replacement (3.4L only):
    http://www.customtacos.com/tech/index.php?article=175
    http://www.4runners.org/writeups/fuelfilter/index.html
    Fuel Filter Replacement (2.7L only):
    http://www.tacomaworld.com/forum/1s...replacement-diy-6-easy-steps.html#post7915911
    Radiator Replacement with Pictures (3.4L):
    http://www.tacomaworld.com/forum/1s...wheres-radiator-swap-thread-pics-1st-gen.html
    ENGINE/PERFORMANCE MODS:
    Turbo Help Threads (5VZ-FE V6):
    http://www.samsonfab.com/phpbb2/viewtopic.php?t=34
    http://www.tacomaworld.com/forum/1st-gen-tacomas/294497-95-5-96-3-4-tacoma-turbo-problem.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/292669-turbo-kit.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/257661-new-turbo-kit.html
    http://www.tacomaworld.com/forum/tacoma-videos/257814-turbo-taco-truck-dyno.html
    Fuel Pump Replacement:
    https://www.tacomaworld.com/threads/brices-turbo-v6-build.437641/page-32#post-13218584
    Deck Plate Mod/Air induction Mod:
    http://home.ezonline.net/~jnburtman/deckplate.html - "How to" Deck plate
    http://www.gadgetonline.com/AirInduction.htm#Modified%20Air%20Box - Dyno testing
    Electric Fan Replacement:
    http://www.samsonfab.com/phpbb2/viewtopic.php?t=11
    Aftermarket Tachometer Install:
    http://www.j5studios.com/projects/toyotatacomatach/
    COSMETIC MODS:
    Back-up camera installation
    Steering Wheel Conversion With Audio & Optional Bluetooth Phone Controls
    Squeaky Clutch Fix:
    http://www.tacomaworld.com/forum/1s...ak-linear-spring-swap-tw-how.html#post3236948
    Window Trim Replacement How-To:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/154485-simple-how-fix-crappy-door-trim.html
    Defrost w/o AC mod (EASY):
    http://www.tacomaworld.com/forum/1st-gen-tacomas/126495-defrost-without-c-mod.html
    Satoshi Grill Write Up:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/222360-satoshi-mod-1st-gen-write-up-lots-pics.html
    Blinker Conversion/Fog light Mods:
    https://www.tacomaworld.com/threads...-turn-signal-mod-thread.445485/#post-13038328
    http://www.lieblweb.com/blinkerconversion.html
    http://www.yotatech.com/f127/parking-light-turn-signal-mod-no-drilling-cutting-210234/
    -Fog Light Mod:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/81243-fog-light-mod-how-pics.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/77781-fog-light-mod.html
    -Switchback LEDs for Turn Signals
    http://www.tacomaworld.com/forum/1s...gnals-running-lights-switchback-leds-how.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/150483-how-install-switchback-leds.html
    http://www.customtacos.com/forum/showthread.php?p=1670194
    Headlights:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/8715-01-04-headlight-adjustment.html - Adjustment
    http://www.tacomaworld.com/forum/1s...00-retrofit-walkthrough-morimoto-mini-h1.html - Headlight replacement to LED (98-00)
    http://www.youtube.com/watch?v=WwSyjKVwl-k&feature=player_embedded
    http://www.youtube.com/watch?v=_b5WTodsY84&feature=player_embedded
    ^ These guys got lots of vids. Not gonna post them, just check them out on youtube.com
    Brake Lights:
    http://www.tacomaworld.com/forum/li...ing-replacing-3rd-brakelight.html#post6167548 - 3rd brake light Led Conversion
    Back up Light Mod:
    http://www.tacomaworld.com/forum/lighting/83616-1st-gen-extra-backup-lights-mod-writeup.html
    Back up Camera Install:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/255014-backup-camera-install.html
    Break Light on Camper Wiring:
    http://www.tacomaworld.com/forum/lighting/181629-camper-third-brake-light-wiring-noob.html
    Interiors:
    http://www.tacomaworld.com/forum/technical-chat/89333-diy-leather-interior.html - DIY Leather Interior courtesy of HomerTaco
    http://www.tacomaworld.com/forum/1s...pet-your-toyota-tacoma-w-dynamat-install.html - New Carpet install with Dyno Mat install
    Power Window Repair:
    Map Light install (rear view mirror):
    http://www.tacomaworld.com/forum/1st-gen-tacomas/175112-map-lamp-question.html
    Tail Gate Repair:
    http://www.tacomaworld.com/forum/at...d1281648951-how-replace-tailgate-97313952.jpg
    Dash Board Removal:
    http://www.customtacos.com/tech/index.php?article=77
    Cup Holder Fix/Mod:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/14384-cup-holder-thingies-2.html
    Paint/Black Out stock rims:
    http://www.tacomaworld.com/forum/wheels-tires/103076-how-painting-your-stock-rims.html
    Aftermarket Key-less Entry Install:
    http://www.tacomaworld.com/forum/1s...llation-aftermarket-keyless-entry-system.html
    Keyless Entry Range Extension Mod:
    http://www.tacomaworld.com/forum/te...e-antenna-wire-radio-antenna.html#post6164825
    Seat Swap How-To:
    http://www.customtacos.com/tech/index.php?article=168
    http://www.customtacos.com/tech/index.php?article=169
    Misc reservoir placement how to's, bumper clearance, etc...
    Speedometer Needle Mod:
    http://www.tacomaworld.com/forum/1st-gen-tacomas/177472-1st-gen-speedo-needle-mod.html
    Mirror Swap mod - from 95-97 mirror to 01-04 mirror
    http://www.tacomaworld.com/forum/1s...w-replace-95-97-side-mirror-01-04-mirror.html
    Cruise Control Install:
    http://www.tacomaworld.com/forum/1s...ol-installation-2002-v6-auto.html#post3104365
    Heater/AC Control Pannel LED Swap:
    http://www.customtacos.com/forum/showthread.php?t=56860
    Lazy Seatbelt Fix:
    http://www.4x4wire.com/toyota/minutemods/seatbelt/
    Change Factory Clock into Voltage Meter
    MISC DIY'ER (SOME TAKEN FROM DIY STICKY):
    http://www.parksoffroad.com/tacomamods/01tacoma.html#sus
    http://4x4wire.com/toyota/
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods.html - DIY Mods/Repairs for Gen 1 and 2
    http://www.customtacos.com/tech/index.php - Bunch of guides
    http://www.tacomaworld.com/forum/technical-chat/4838-cheap-free-mods.html - Cheap/Free Mods
    MANUALS:
    2004 Tacoma Spec Sheet:
    http://www.customtacos.com/tech/files/specs/04/04_specs.pdf
    Toyota Tool to look up Required Maintenance:
    http://smg.toyotapartsandservice.com/index.php
    http://www.tacomaworld.com/forum/1st-gen-tacomas/174329-2001-toyota-scheduled-maintenance-guide.html
    Factory Service Manual:
    http://web.archive.org/web/20080731033603/http://www.ncttora.com/fsm/
    http://www.toyotapartszone.com - OEM Part numbers (partial) and diagrams (diagrams are now available again, linked to from a different site)
    http://www.toyodiy.com - Complete OEM Part numbers but no diagrams. Uses the same reference diagrams as toyotapartszone.com.
    https://auth2.toyota.com/owners/app....do?siteid=too_toyota_btmnav_ownersinfoupdate - Used Toyota Car/Truck service history
    http://www.amsoil.com/mygarage/vehiclelookup.aspx?url2=2001+TOYOTA+TACOMA+8 - Lubricants and Fluid Guide
    Enjoy!
  2. May 29, 2010 at 6:34 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Awesome!
  3. May 29, 2010 at 8:01 PM
    strongwxnc
    strongwxnc Well-Known Member
    Bostic, NC
    2002 Xtra Cab SR5 2.7L 4WD
    Bushwacker bed rail caps
    Very cool thread idea man..
  4. May 29, 2010 at 8:05 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    BatteredTaco likes this.
  5. May 30, 2010 at 4:21 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    ^ Sweet! Didnt see that thread. I added it to my post as well, however Im trying to focus primarily on Gen 1 Tacoma's.
    Brie likes this.
  6. May 30, 2010 at 12:20 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
  7. Jun 1, 2010 at 1:31 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Thanks, updated.
  8. Jun 21, 2010 at 6:01 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  9. Jun 21, 2010 at 6:18 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    awesome work man!!! rep for putting it together! :thumbsup:
  10. Jun 21, 2010 at 8:46 AM
    ywen
    ywen Well-Known Member
    Thanks! MOD: plz make this a sticky.
    PurpleRain likes this.
  11. Jun 26, 2010 at 6:53 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  12. Jun 26, 2010 at 8:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Water pump replacement 3.4L
    Steering rack bushing replacement 3.4L
    2.5" cornbred spacer lift
    2.5" daystart spacer lift
    Oxygen Sensor replacement 3.4L
    Clutch Pedal bushing replacement
    Blinker conversion
    Ebrake adjustment
    *these are my own personal write-ups.
    Brie likes this.
  13. Jun 26, 2010 at 3:54 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Awesome, thanks!
    Reformated for easier use.
  14. Aug 3, 2010 at 9:54 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
  15. Aug 3, 2010 at 11:34 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    great thread...i was wondering about electric fans, that's a great write up
  16. Aug 3, 2010 at 12:10 PM
    scocar
    scocar hypotenoper
    Two (lying) things:
    1. I suggest that "1st Gen" be inserted at the beginning of thread title.
    2. I suggest that we request it be added to the Mods and Tutorials Nav Button, so it is as easy as possible to find (especially for noobs).
    3. I suggest it be stickied under 1st gen forum.
    4. I suggest that the mods do this now (Hello, is there a mod in the house?)
    5. I suggest you get mad props. This is sorely needed. It takes effort, good job!
    BatteredTaco and Brie like this.
  17. Aug 3, 2010 at 7:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This is one of the most useful, helpful threads to come along in some time. Please make it more visible.
  18. Aug 4, 2010 at 3:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    damned good job ladies and germs.:D
  19. Aug 4, 2010 at 4:17 PM
    scocar
    scocar hypotenoper
    :headbang::rockband::headbang:
    :taco::taco::taco::taco::taco:
    StAndrew, hope you don't mind, but I grabbed the thread by the, uh, string and PMd the mods and issued our demands....it now appears in the Mods &Tutorials drop-down navigation, and is stickied under 1st gen, and I had them add 1st gen to the title.
    Full props to the Saint! Great site contribution! And thanks to TcBob and Tacomaman06 for anointing your thread with the high honor it deserves! :cheers:
    Now we all have to send StAndrew future goodies so he can add to the wealth in post #1.
  20. Aug 5, 2010 at 9:54 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Thanks man! Though the props should be given to those writing the articles. Its not much trouble on me to put links into a thread ;). Please post any other links here or PM me and Ill get them added.
